APG with multiple GPUs
mattspace
Likes: 4 posts
by mattspace » Wed Apr 05, 2017 7:55 am
I know APG doesn't support splitting tasks across multiple GPUs, but how does it deal with a situation where you might have multiple GPUs installed, have your displays plugged into one card, but want APG to use a different / more powerful non-display GPU?
Do you still get any UI / responsiveness speedup, or does that depend on APG running on the same GPU that is handling display output?
olivierbo
Liked in: 134 posts
Re: APG with multiple GPUs
by olivierbo » Wed Apr 05, 2017 1:03 pm
Hi Matt,
In Windows systems, Nvidia Control panel you can select Autopano to be used with the GPU you want. I do not know if there's a similar option with AIT GPU.
Hope this helps.
Best regards,
Olivier
