Batch rendering: Setting the output folder for all images
panoheader
by panoheader » Fri Mar 17, 2017 12:54 am
Hi!
When I batch render several images and I want to save them in a certain location, Autopano requires me to enter the destination folder for every single image. Is there a way that I can set it once for the whole batch?
I also like to have the option "add a numerical suffix..." checked, but again I need to select it for each and every image separately.
This is quite annoying when I process 100 panoramas :).
I am sure there is a solution to this.
Any suggestions? :-)
Thanks!
Panoram1x
Liked in: 41 posts
Re: Batch rendering: Setting the output folder for all image
by Panoram1x » Fri Mar 17, 2017 10:55 am
Hi
In the main window of Autopano ... Edit ... Settings ... render tab ... output.
You can change the settings there. Restart Autopano and those will be the default settings.
panoheader likes this post.
panoheader
by panoheader » Fri Mar 17, 2017 8:02 pm
Awesome. This is just what I was looking for. Thanks a lot!
goomedia
by goomedia » Tue May 09, 2017 3:37 pm
I don't have the settings option in the edit menu!
