Transition between masks not working
gletsjer
by gletsjer » Tue Aug 23, 2016 9:03 am
I'm using the mask feature in AVP to hide a parallax issue where a person is walking through a stitchline. I'm using the same technique as described in this tutorial on the youtube Kolor channel: https://www.youtube.com/watch?v=5eZmxN9sid8
However, whatever I choose the 'interpolation type' of the transition between the masks to be, nothing happens. In fact, there is no (smooth) transition, the masks cut from one to the other on 1 frame at the middle of the transition, no matter how long I make the transition.
Any idea how I can make the transition smooth, instead of a hard cut?
Thanks.
tasheal
Likes: 4 posts
Re: Transition between masks not working
by tasheal » Tue Aug 23, 2016 5:20 pm
You can record your screen with result.
Record screen can Quicktime and upload to youtube for show us
