Fixing errors
greytail
Fixing errors
by greytail » Fri Jul 08, 2016 11:57 pm
Hi:
I have an auto pano here but it has some slight errors....in the tree line and in the road. How do I fix this in Auto Pano or on Panotour. I have both pieces of software.
Here is the url of the pano
http://www.droneflynewengland.com/willo ... ughby.html
It was taken with an Inspire Pro, an Olympus 12mm, using DronePan and 71 images.
Overall, I am very pleased with some software :)
DrSlony
Re: Fixing errors
by DrSlony » Sat Jul 09, 2016 11:51 pm
Hey
Why 71 images? With a 24mm ff equivalent (which I believe your 12mm is), you need only about 10 shots. Too many shots = stitching errors.
Make sure your control points are on the trees, not on the clouds.
If you have reason to believe that your "device" moved (drone), you could right-click on a photo in the panorama editor window and set it to "optimize viewpoint" (don't have Autopano in front of me right now to check the exact name), then re-optimize.
