Misalignment   [SOLVED] - View the solution
VPS
Liked in: 3 posts
Misalignment
by VPS » Fri Jun 17, 2016 1:22 pm
Can someone please help with a misalignment caused by the sunrise?
olivierbo
Liked in: 134 posts
Re: Misalignment
by olivierbo » Mon Jun 20, 2016 9:54 am
There are several reasons to get this issue. Have you tried "Simple row or column" option in the Detection tab for instance?
Kind regards,
Olivier
VPS
Liked in: 3 posts
Re: Misalignment
by VPS » Mon Jun 20, 2016 9:55 am
olivierbo
Liked in: 134 posts
Re: Misalignment
by olivierbo » Mon Jun 20, 2016 9:59 am
Based on the way you shoot, you can use this option (see the documentation). Also, this can be due to a lack of details and many other reasons if your pictures are not stitched properly.
VPS
Liked in: 3 posts
Re: Misalignment
by VPS » Mon Jun 20, 2016 10:01 am
Nope - that didnt work....
I tried using Congtrol Points editor and it looks better....
https://s3.amazonaws.com/vps-panorama/O ... ntred.html
marzipano
Liked in: 14 posts
Re: Misalignment
by marzipano » Mon Jun 20, 2016 11:52 am
Looks like the effects of parallax differences to me
Being a "hand held" panorama person quite often I have seen this myself when shooting landscapes hand held especially when there are items close to the camera as well as in the distance and control points are used to align the foreground (results in crooked or disjointed horizon)
Might be worth trying the "Multiple Viewpoints" option if the above is the case for you otherwise crop out some near foreground or resort to Photoshop !
VPS
Liked in: 3 posts
Re: Misalignment  [SOLVED]
by VPS » Mon Jun 20, 2016 11:55 am
I think it was the early morning sun blitzing the horizon out. I have also used the control points editor to clean up the stitching.
https://s3.amazonaws.com/vps-panorama/O ... Fixed.html
I still cant understand why, when i save the jpg pano, then edit in Lightroom and re-save teh edited pano, after importing to PanoTour it becomes very warped. Its as if LR is changing the aspect ratios when re exported...
I dont really want to edit every component image in LR - I prefer to edit the stitched pano.
Anyone?
