Nadir replacement blending in   [SOLVED] - View the solution
CaiusC
by CaiusC » Wed Jun 15, 2016 10:14 am
I have a logo to cover over the nadir that is on my panorama, but it keeps blending into the panorama rather than being a separate image. I have already renamed the layer as "Patch" and separated it from the stitch, but its still blending into the panorama. How do I fix this?
Re: Nadir replacement blending in  [SOLVED]
by Annis » Wed Jun 15, 2016 10:34 am
Did you activate the quick preview?
viewtopic.php?f=2&t=31754&hilit=quick+preview#p182775
CaiusC
by CaiusC » Fri Jun 17, 2016 9:50 am
Ah yes that worked. Thanks very much.
Annis likes this post.
