Render Settings   [SOLVED] - View the solution
vertrider
Render Settings
by vertrider » Sat Jun 11, 2016 1:56 pm
Good Morning ;),
How can I permanently save the settings in the render dialog...
While AutoPano is open, each time I start a render, I have to again choose and set
Format, Quality and DPI as well as Output Folder.
I would like to have these settings permanently stored, even after closing AutoPano.
Thanks for any help!
Cheers
Christoph
Re: Render Settings
by Destiny » Sun Jun 12, 2016 1:55 am
Hi.. Sorry to say its not possible to save presets in APG... I have always wanted this feature with HDR and LDR.. Each and every time they need to be set from scratch...
Re: Render Settings  [SOLVED]
by Annis » Mon Jun 13, 2016 8:16 am
Set those settings in the general preferences, not the render window of the the panorama editor.
The new preferences will be used for future projects, if you already started the detection of new panoramas they will use the old general settings.
Autopano Giga 64bits 4.2.3.png (9.78 KiB) Viewed 663 times
http://www.kolor.com/wiki-en/action/vie ... ferences...
vertrider
Re: Render Settings
by vertrider » Mon Jun 13, 2016 9:57 am
thank you very much!
that has done it :)
Cheers
Christoph
