Black hole Problem...
sokard
by sokard » Mon Apr 04, 2016 4:09 pm
Hi everyone,
I try to work on some 360Vr.
And I have a serious problem and I can't find any solution...
There is a transparency area on my Autopano Giga project and that's make a black hole on my preview/render.
I'm working with the last version software (Autopano Pro Video and Giga).
There is only two images, but i work with 2 gopro with Entaniya fisheye 280°.
Someone can explain how to fix it ?
Thx
olivierbo
Liked in: 133 posts
Re: Black hole Problem...
by olivierbo » Tue Apr 05, 2016 10:34 am
Can you crop your pictures by opening the Image properties window, then Circular crop tab? Add control points if needed.
Kind regards,
Olivier
sokard
by sokard » Tue Apr 05, 2016 11:04 am
olivierbo wrote:Hello,
Kind regards,
Olivier
Thanks for your answer !
This is my image properties
My images info
And my crop images [img]
[/img]
My images info
olivierbo
Liked in: 133 posts
by olivierbo » Tue Apr 05, 2016 2:00 pm
I do not change the focal lenght (0.00) but the lens type to fisheye, then detect to get something properly stitched. That said, it can depend on the content. This is quite difficult to get something great with this configuration without adding CP.
You can also try to select Spherical as the filtering model in the Detection tab.
Kind regards,
Olivier
