HELP: Mask Will Not Expand in APG 4.2
aquabluleo
Likes: 3 posts
Liked in: 3 posts
by aquabluleo » Thu Mar 31, 2016 12:11 pm
Please see attachments Screenshots... 1-2-3-4.
IMAGE-1: This is the camera mask I need to expand.
IMAGE-2: Adding a Marker, expands the mask slightly...
IMAGE-3: I keep adding markers and the mask will not expand more...
IMAGE-4: If I try to add a marker beyond the camera border...it then activates the other camera mask!
After an hour of various attempts to expand the mask...beyond the person's parallaxed head...I have exhausted all options.
==> Please give me feedback asap I need to fix this.
==> Is this a bug in Giga...?
aquabluleo
Likes: 3 posts
Liked in: 3 posts
Re: HELP: Mask Will Not Expand in APG 4.2
by aquabluleo » Thu Mar 31, 2016 12:15 pm
Martin, I have followed your detailed settings (below) and still unable to expand the or push the seam further beyond the parralaxed persons's head...(the first marker nudged a bit but can't go beyond to fix problem)
<<<< You cannot see any effects of your masks because you are using a smooth blending (DIAMOND), so in APG go into the blend icon, blending: multiband, level -2, cutting ISO, no Weighting. In AVP, blend -> sharp.
Then you should be able to push the seams.>>>
aquabluleo
Likes: 3 posts
Liked in: 3 posts
by aquabluleo » Tue Apr 19, 2016 2:44 pm
Can someone confirm if this is a bug or problem in Kolor Software osx version?
