MASK in Photoshop
Parentesi
Likes: 3 posts
MASK in Photoshop
by Parentesi » Mon Nov 16, 2015 9:22 pm
Hi
So I would love to be able to mask images in Photoshop.
There is a Tutorial from Kolor on how to do it:
Use the Ad A Mask tool in PS, draw the areas you do not want, save file.
Sounds simple, does not work:
The files then sho up in Autopano as White areas, not transparent. When rendering, then they are also white and blent with the other images behind it.
I also tried to use Alpha-Chanels in PS. They have "0" effect.
So, does anyone have an Idea how to make this work?
The final visible blending of the now White and not transparent area.
Screen of the Transparent Area in PS
Lower Area I want to not be visible, not be used. You can see it is white here, not transparent
upper area with the area the overlaps the white area.
Parentesi
Likes: 3 posts
Re: MASK in Photoshop
by Parentesi » Tue Nov 17, 2015 10:44 pm
So I found a solution for this, but the results are not good. At the boarders of my area I masked in Photoshop, there are hard linse visible in the rendering.
How does it work:
1. Mask the area in PS, so you have now a mask layer.
2. Right-Cklick on it and say: Make selection.
3. Invert Selection
4. Go to the Chanels
5. Klick on the bottom: Mask from Selection. A new Alpha Channel is created. click to make it visible.
6. Save the file.. when updated in Autopano, this is now transparent
Downside:
The render show a hard line at all your Masked areas, as Autopano does not smooth things out there as it does on other overlapping areas.
Conclusion:
PTGui does a much more superior job on Masking.
The only time I would use Autopano, is when the shots where not recorded very accurate, this is where Autopano shines and still corrects everything. But workflow is a pain.
martin.arnoux
Liked in: 27 posts
by martin.arnoux » Wed Nov 18, 2015 3:05 pm
What image format (with which settings) are you exporting from Photoshop?
I just tried with a PNG non-interlaced and it's working fine.
Can you send us your patched image?
Cheers,
Martin
