Beginner Can't Get HDR Layer Output Option Again
Setter User
by Setter User » Thu Jul 09, 2015 9:00 pm
The first day I ran APG, I was able to specify Layer output with Enfuse or HDR selected in the Render window. Since that time, I made the mistake of playing around with some of the settings (my normal learning method), and whenever I get to the Render window, the Layer button is grayed out.
Any suggestions on how to recover that option?
Re: Beginner Can't Get HDR Layer Output Option Again
by mediavets » Thu Jul 09, 2015 9:09 pm
Setter User wrote:The first day I ran APG, I was able to specify Layer output with Enfuse or HDR selected in the Render window. Since that time, I made the mistake of playing around with some of the settings (my normal learning method), and whenever I get to the Render window, the Layer button is grayed out.
Does this post provide any useful information?
viewtopic.php?f=2&t=24898&p=154619&hilit=layers+export#p154621
Setter User
by Setter User » Mon Jul 27, 2015 8:35 pm
No because I don't the Layer option is grayed out so that I can't select it.
Cliquetsy
Likes: 106 posts
Liked in: 119 posts
by Cliquetsy » Mon Jul 27, 2015 9:00 pm
Could you send us a screenshot of your layers window, render window when you've selected your render file format?
marzipano
Liked in: 14 posts
by marzipano » Mon Jul 27, 2015 10:24 pm
When you were playing with the settings I think you adjusted the "Default Regroup" box in the panorama tab in the settings
This one has to be set to "bracket" or "stack" to switch on the layer export (I think)
best
Martin
Setter User
by Setter User » Thu Jul 30, 2015 1:33 am
Martin,
Thank you, that sounds promising! However, please recall I'm a new AGP user, so I don't quite understand the reference to "panorama tab in the settings" -- which "setting" should I look at.
Thanks,
Bruce
Cliquetsy
Likes: 106 posts
Liked in: 119 posts
by Cliquetsy » Thu Jul 30, 2015 6:53 am
Its difficult to help you or shoe you what you may or may not have done wrong without the slightest indication of what you are doing. Some screenshots of your workflow and settings would be extremely helpful
I'm not from the psychic part of the forum where marzipano seems to be from ;)
marzipano
Liked in: 14 posts
by marzipano » Thu Jul 30, 2015 7:53 am
I didn't have a problem with understanding the question :)
Sounds like a bigger problem understanding my answer though
this is what I meant
