Multiple focal length workflow
cartman
Likes: 4 posts
by cartman » Fri Apr 24, 2015 12:11 pm
Hello, I am a new user of your great software, and I have this use case:
I want to make a panorama using my 35mm lens (Sigma 35mm F/1.4) and to zoom in some far away areas with my 200mm lens. I have a Nikon D600 and I use the excellent Panoneed panorama head.
Which is the best workflow in order to achieve what I want?
The instructions from http://www.kolor.com/wiki-en/action/vie ... _stitching do not work in my case, detection messes everything up.
This i what I do: I shot a full panorama with the 35mm lens (51 images in this case), and then shot another 21 images with the 200mm from the far away area I want to focus on. Both have their xml file, and the tripod was not moved. The problem is that I cannot import 2 xml files at the same time, so I am forced to import the 35mm one, and then drag and drop the 200mm images into the panorama. Unfortunately the detection code messes everything. Am I doing something wrong?
Re: Multiple focal length workflow
by mediavets » Fri Apr 24, 2015 12:52 pm
Welcome to the forum...
I seem to recall that the ratio between shorter and longer focal lengths cannot exceed 1:4.
Ah yes, here's the relevant info in the documentation:
cartman
Likes: 4 posts
by cartman » Fri Apr 24, 2015 1:00 pm
Yes you are right, I have seen that too. Is this a hard limit or can it be bypassed?
by AlexandreJ » Fri Apr 24, 2015 2:02 pm
It cannot be bypassed as it is a limit in the control point detection algorithm.
Nevertheless, if you are okay adding control point manually one by one, then you can stitch.
cartman
Likes: 4 posts
by cartman » Fri Apr 24, 2015 2:04 pm
I just had an idea, can I create a panorama of the 200mm images, and then drag it into the 35mm one?
