iStar stitch issues !   [SOLVED] - View the solution
vincen
Kolor Certified Trainer
Likes: 23 posts
Liked in: 4 posts
by vincen » Thu Mar 19, 2015 9:48 am
Hi
I encounter an issue using the NCTech import filter. I shooted the panorama in HDR in the iStar (9 steps, so 36 shoots).
I extracted the JPG from the RAW file with NCTech Immersive sofware than gave them to NCTech import filter in APG and with default settings ! Unhappy it tells me after detection that RMS is very good 3.65 but Editor tells me that it found 8 different panoramas :(
How is that possible ? and what's wrong ?
RAW file from iStar avalaible on this link: https://drive.google.com/file/d/0B68T7D ... sp=sharing
Side note: no way to give directly the NCTech raw file to APG ? (to avoid extra step with Immersive to split the raw file !
Vincèn
vincen
Likes: 23 posts
Liked in: 4 posts
Re: iStar stitch issues !
by vincen » Fri Mar 20, 2015 2:26 pm
No one has any idea what's the problem ?
Lionel Laissus
Re: iStar stitch issues !  [SOLVED]
by Lionel Laissus » Thu Apr 02, 2015 3:38 pm
APG doesn't support directly .nctri file (Private file format) but jpeg files (even bracketed)
Use Immersive Studion to export .nctri files to JPG files (check EXPORT SOURCES JPEGS)
Render from 9 brackets:
9bkt
Render from 4 brackets: (I selected the relevant one)
I selected the relevant brackets (I kept 4 bkt)
vincen
Likes: 23 posts
Liked in: 4 posts
by vincen » Thu Apr 02, 2015 3:53 pm
Lionel Laissus wrote:APG doesn't support directly .nctri file (Private file format) but jpeg files (even bracketed)
Hi Lionel
Thanks for answer but it's what I did ! I converted the unique RAW file from iStar in JPG with Immersive studio and then passed all JPEG to APG !
When I select the folder with all JPEG generated by Immersive Studio, APG confirms it found one pano ! but then it goes directly to detection and then in Editor it says me it found 8 different panos :( I did something wrong ? pano is shot in HDR for info.
Lionel Laissus
by Lionel Laissus » Thu Apr 02, 2015 4:18 pm
It worked fine on APG 4.0.0
My folder:
vincen
Likes: 23 posts
Liked in: 4 posts
by vincen » Thu Apr 02, 2015 4:38 pm
Lionel Laissus wrote:It worked fine on APG 4.0.0
Yep but I'm confused by fact it states that it discovered 8 panos when you open it in editor !
Lionel Laissus
by Lionel Laissus » Fri Apr 03, 2015 1:50 pm
Actually it's totally fine that APG discovered 8 sub-panoramas.
Because the bracketed/stacked pictures are not connected together, it's like having (1+8) panoramas on the top of each other without any inter-connection between them...
vincen
Likes: 23 posts
Liked in: 4 posts
by vincen » Wed Apr 08, 2015 1:41 pm
Lionel Laissus wrote:Actually it's totally fine that APG discovered 8 sub-panoramas.
Thanks Lionel for explanations, much appreciated :)
