Green Stains after rendering   [SOLVED] - View the solution
MartinP
by MartinP » Sat Jan 24, 2015 9:57 pm
In some panos I have some green stains after I rendered them with autopano giga 3.7. I'm wondering why they appear. At first, here is a picture:
This pano includes 12 pictures, each view has three different exposed pictures for HDR.
Here are my render-settings:
The only thing I thought about is that the chromatic aberrations from the lens are not completely corrected and autopano increases their appearence, but in this case there should be more stains I think. Has anyone an idea how to prevent this stains so that they don't appears after render. Currently I must remove them with the brush-tool in photoshop.
Greetings
Re: Green Stains after rendering
by mediavets » Sat Jan 24, 2015 10:02 pm
Did you shoot with auto white balance?
MartinP
by MartinP » Sat Jan 24, 2015 10:06 pm
Yes but they also appear when I change the white balance of the raw-files in photoshop.
by mediavets » Sat Jan 24, 2015 10:10 pm
What else was set to auto?
MartinP
by MartinP » Sat Jan 24, 2015 10:15 pm
I used auto exposure time and auto aperture. But the seperate pictures doesn't have this stains, they appear only after the render with autopano.
by mediavets » Sat Jan 24, 2015 10:18 pm
Also auto ISO?
What camera and lens were you using and at what focal length.
Did you use a pano head and a tripod?
What were the exposure bracketing settings?
MartinP
by MartinP » Sat Jan 24, 2015 10:26 pm
It seems that I haven't given enough information. Sorry for that.
I use a Canon EOS 700D with a Canon EF 8-15mm 1:4 L Fisheye lens and additional a tripod with a pano head. The iso is set to 100 and the focal length was 8mm. Further more the exposure bracketings settings were -2/0/2.
by Destiny » Sat Jan 24, 2015 10:27 pm
Hi... Are you able to share those RAW files..
MartinP
by MartinP » Sat Jan 24, 2015 10:43 pm
Not from this scene, but there is another example, on the traffic sign are red stains:
You two will get the link for raw images via pn.
by Destiny » Sat Jan 24, 2015 11:01 pm
Your problem is WB.. You need to check what you have it set to.. The RAW should have that data.. RAW should also be able to fix it to a high degree but never as perfect as getting the WB right from the start.. Types of cameras react differently...
by Destiny » Sat Jan 24, 2015 11:09 pm
Are you doing your fusion in APG.. If so, did you set Auto Colour correction..
MartinP
by MartinP » Sat Jan 24, 2015 11:28 pm
Ok in a guide book stands it's the same when you set the wb during the captioning or after it in e.g. ps. I will do the wb setting during the caption in the future. But this can't be the solution for my problem or am I wrong?
Yes I fusion them in APG. The color correction mode is on "HDR" like the "workflow case E" says in kolor's wiki. I tone-map the panos in Photoshop.
PS: sorry for uploading the raw-data on google drive :D
by Destiny » Sat Jan 24, 2015 11:53 pm
Hi.. I did not get the issue you have.. I need to go out now.. I will look into it more later...
by Destiny » Sun Jan 25, 2015 8:56 am
Hi... I really cannot reproduce the green ting effect you are experiencing.. The colour correction in APG V4 works amazingly well.. I just set your RAW to daylight and removed chromatic aberration..
by mediavets » Sun Jan 25, 2015 9:04 am
Did you put the RAW images into APG or process them with third party software before input to APG?
by Destiny » Sun Jan 25, 2015 9:49 am
I set the images to daylight and used the setting chromatic aberration, which is what I always do with RAW... Just incase. Then exported as JPG, or TFF..
I then put the images into APG and you can see the results.. RAW can cause issues.. Fine until the HDR is ticked in edit..
After that it goes yuck... I would rather deal with JPGs or TIFFs in APG.. After editing them in RAW....
But.. despite the fact the HDR is horrible in APG, I still do not see the green ting...
by klausesser » Sun Jan 25, 2015 2:44 pm
MartinP wrote:Hello,
Hey Martin!
Deactivate the use of "Gamma" in the "ColorCorrection". Ideally use only "Exposure".
MartinP
by MartinP » Sun Jan 25, 2015 4:21 pm
I'm really confused right now. I tried to play around with the settings in apg and I saw that destiny used in the colour- and brightness transitions the value -8. I tried it, too but the render was horrible.
Here with -2. You can see that with this setting you can see these stains and I can't find any value that removes it nicely.
When I'm in the color anchor mode there are no stains:
Gamma is off and so is color correction, too. I always set the wb, the sharpness and remove chromatic aberration in the raw-files. I save them as jpg and put them into apg.
One additional question: Why do you (destiny) set you the color anchor "auto" and not "hdr"? Is the hdr setting when you want to tone map the pano in apg? Is it better to set it to auto to tone map it in ps?
by klausesser » Sun Jan 25, 2015 5:00 pm
MartinP wrote:Gamma is off and so is color correction, too.
Better activate color correction! It´s very valuable to have it on.
HDR in APG isn´t preferable. For tonemapping better use Photomatix first
and stitch the mapped images then.
by klausesser » Sun Jan 25, 2015 5:09 pm
MartinP wrote:I used auto exposure time and auto aperture. But the seperate pictures doesn't have this stains, they appear only after the render with autopano.
One basic suggestion: NEVER use ANY automatic setting when you shoot panos. ;)
ThomasV
by ThomasV » Mon Jan 26, 2015 9:01 am
Hello Martin,
It would be nice if you could share the photographs. We will give a look at this issue and try to reproduce that.
Thanks,
Thomas
MartinP
by MartinP » Mon Jan 26, 2015 10:00 pm
Hello at all,
I was trying around all the time an now I'm using photomatrix before I stitch the pictures together. I don't have any stains now and I think the result is pretty good.
Thank you all for your support!
by Destiny » Mon Jan 26, 2015 10:08 pm
Hi.. You can also use EnfuseGUI which is free and very good for fusion tone mapping... No good for HDR..
The HDR option in APG is very difficult to use and is hardware depenent.. Its got some great features but the end results often does not represent the final render and its very hard to get an acceptable render.. Even if you did achieve a good result, there is no way to batch process the same settings. You cannot use those same settings as a preset for images captured a the exact same time... Much better to use Photomatix or EnfuseGUI.. Photomatix has presets which is great..
