New install : autopano4 don't start
Re: New install : autopano4 don't start
by AlexandreJ » Wed Dec 31, 2014 2:42 pm
Thanks for the tests. It confirms us that it is a compilation issue on 64bits with optimization.
We'll probably get back to one of you for testing several compilations until we found out the right one that pleases the phenon processor.
zbigi
by zbigi » Thu Jan 01, 2015 6:46 pm
The problem is not concerning only phenom processor.
i am using FX-6100 six-core AMD processor and I have the same problem. My system is Windows 7 Enterprise 64-bit. My computer is equiped with 8 GB RAM.
Working with 32-bit version is difficult because if very small amount of RAM accessible for the AP program. It is insufficient during the work with high resolution pictures.
by mediavets » Thu Jan 01, 2015 7:22 pm
zbigi wrote:The problem is not concerning only phenom processor.
I think the issue is more precisely with non-Intel CPus.
dang-eid
by dang-eid » Thu Jan 08, 2015 4:43 pm
SOLVED for me in 4 beta 3
zbigi
by zbigi » Fri Jan 09, 2015 6:56 am
Yes. The issue (according thread issue) is solved in the Beta 3 version for my FX-6100 processor.
But - on my computer - Windows have discovered that the program is not running properly and it have announced, that it has to set the compatibility settings which will be applied since the next AP executing.
Previous
