New install : autopano4 don't start
roland_d_alsace
by roland_d_alsace » Thu Dec 25, 2014 7:05 pm
Hi.
I have installed autopano 4 for the 1st time.
No problem at install.
When i want to start, nothing, autopano don't start.
Is it a log file or somethink to help to find the problem ?
Configuration :
Autopano 4.000B2 2014-12-19
Windows 7 64bits AMD Phenom II X6 1090T 12GB + 256GB SSD
3 display cards with each 2 monitors
2x ATI Radeon HD5700 1x AMD Radeon HD 6450
HansKeesom
Re: New install : autopano4 don't start
by HansKeesom » Thu Dec 25, 2014 7:33 pm
Interesting to see you have 3 displaycards. As 4.0.0. has a faster editor and does more with the GPU I am wondering if the problem is caused by you having 3 cards. No hard indication however...
by mediavets » Thu Dec 25, 2014 7:39 pm
roland_d_alsace wrote:Hi.
Beta 1 or Beta 2?
roland_d_alsace
by roland_d_alsace » Thu Dec 25, 2014 8:02 pm
Hi mediavets.
B2 2014-1219...
...like said in my post
roland_d_alsace
by roland_d_alsace » Thu Dec 25, 2014 8:34 pm
I have try to install Autopano 4.000B2 2014-12-19 in another computer a laptop i7-4710HQ + 16GB / SSD 256G + 1To + Nvidia GTX860M / W8.1 x64
I see that at the beginning of the 1st install Window ask to restart and i refuse (i have already see it in my other computer).
Here AutoPano 4.00B2 start well.
But in editor i don't have the pictures displayed (only the grid).
Regards...
...and mery Christmas !
HansKeesom
by HansKeesom » Fri Dec 26, 2014 12:15 pm
So we get the idea here that if you don't restart immediately after installation you might have a problem...
roland_d_alsace
by roland_d_alsace » Fri Dec 26, 2014 6:36 pm
I have restart, of course, but nothing do, autopano4.00B2 don't start...
...without displaying error,
i have the waiting icon (hourglass) a few seconds, its all.
HansKeesom
by HansKeesom » Fri Dec 26, 2014 7:06 pm
and how about deinstalling an reinstalling, all with restarts in between?
roland_d_alsace
by roland_d_alsace » Fri Dec 26, 2014 7:49 pm
Hi
I have also made this yesterday before posting.
Do you know if there are a log file for autopano ?
AutopanoGiga3.7 and PanotourPro 3.2 run without problems.
dang-eid
by dang-eid » Sat Dec 27, 2014 9:48 pm
Still no luck getting beta 2 to open too. 371 works fine. win7, 64bit, nvidia geforce drivers updated. have uninstalled a couple times, restarted and reinstalled the beta2. little hourglass shows for maybe a second and then nothing else ever happens.
by mediavets » Sat Dec 27, 2014 10:31 pm
dang-eid wrote:Still no luck getting beta 2 to open too. 371 works fine. win7, 64bit, nvidia geforce drivers updated. have uninstalled a couple times, restarted and reinstalled the beta2. little hourglass shows for maybe a second and then nothing else ever happens.
APG 4 beta 2 seems to install and run OK for me, Dell T3400 Win7 Pro 64-bit, nvidia Quadro FX570.
Did you uninstall 4 beta 1 before installing 4 beta 2?
dang-eid
by dang-eid » Sat Dec 27, 2014 11:37 pm
yes uninstalled beta 1; which did the same no start.
by Destiny » Sat Dec 27, 2014 11:48 pm
... did you reboot after uninstalling B1..
dang-eid
by dang-eid » Sat Dec 27, 2014 11:50 pm
think so. that was a while back.
by Destiny » Sun Dec 28, 2014 12:05 am
I suggest you uninstall all Beta 4s and then reboot.. Then try to reinstall B2.. Its worth a try... Easy with a Mac, just dump the entire folder but a PC tends to fragment files...
dang-eid
by dang-eid » Sun Dec 28, 2014 1:28 am
done that. Now waiting for beta 3...
by Destiny » Sun Dec 28, 2014 2:07 am
Well, at least its only a beta version but still very annoying for those with issues..
Hopefully Beta 3 will not be too far way.. I suggest you remove all beta's before trying to load B3..
What opp system, Win versions etc do you have..
dang-eid
by dang-eid » Sun Dec 28, 2014 3:10 am
win7, 64bit, AMD phenom II x4 945 processor 3.00GHZ; 16GB ram; NVIDIA GTX 550Ti (1GB)
by Destiny » Sun Dec 28, 2014 4:02 am
Going by the specs you should be ok...
http://www.kolor.com/download#faq
Just have to wait for Kolor to fix this bug issue..
by AlexandreJ » Mon Dec 29, 2014 5:35 pm
It seems more about the CPU support itself ( GPU is not really called at startup ). We do optimize a lot for Intel, and perhaps it can create issues with that Phenom processor.
We'll need to check that case : Issue 4247 opened
by AlexandreJ » Tue Dec 30, 2014 10:21 am
dang-eid : could you do the following test
- download the 32bits version of autopano 4 here : http://www.kolor.com/download#autopano
- try it on your AMD Phenom
Report here if it works or not.
The 32bits version is compiled without any CPU optimization. Thus, it may work on a wider range of CPUs. If the 32bits works, it will confirm us that the problem is an compilation issue.
luck72
Likes: 4 posts
by luck72 » Tue Dec 30, 2014 2:28 pm
Me too!!! I have an AMD cpu and the new APG 4 works only in 32bit version. No way to start it in 64 bit version.
Nikon D810, Nikkor 16mm fisheye,20mm, 50mm, 85mm, Amarula Bushman Tripod, Gobi panoramic Head, Windows 10/64bit, Adobe Photoshop CC 2018, Lightroom Classic CC 2018, APG 4.4.1, PTP 2.5.11
dang-eid
by dang-eid » Tue Dec 30, 2014 3:27 pm
AlexandreJ wrote:dang-eid : could you do the following test
The 32bit does install and run.
but
Crash during detect " Error during detection Too few memory .\FindPanorama.cpp"
luck72
Likes: 4 posts
by luck72 » Tue Dec 30, 2014 3:57 pm
also for me the 32 bit start but it recognize only 900 mb of RAM and is really slow to render!!!!
HansKeesom
by HansKeesom » Tue Dec 30, 2014 6:54 pm
see last few postst of
viewtopic.php?f=109&t=24774
