[400b2] Cannot set color correction mode for all images
DrSlony
by DrSlony » Sat Dec 20, 2014 3:16 pm
You can right-click on an image to set the color correction mode (Anchor/Gamma/Exposure/Color/Vignetting/Gradient) of that image, but I have not found a way of doing that for more than one image at a time.
marzipano
Liked in: 14 posts
Re: [400b2] Cannot set color correction mode for all images
by marzipano » Sat Dec 20, 2014 4:40 pm
Ctrl/click worked for me in 4.0B2 to select multiple images then right click and select makes the same change in all of them
Shift/click a range did not work though
Martin
