APG 4.0 beta 1
HansKeesom
APG 4.0 beta 1
by HansKeesom » Fri Dec 19, 2014 11:45 pm
First glance : userinterface not changed, fortunately. My GPU is much better used and no sign of the famous last core problem. All we wait for now is the price of final version/ update price when having 3.5 already.
Me think I am using the beta for a while now. as things only seems to go faster.
Coming from a rather critical person like myself, this is good news!
....oops fist crash, ran out of memory. Guess editors are leaking again/still
and half an hour later, back to 3.7 as the beta is crashing all the time
Programm suddenly disappears from my screen a few times. No crashreport made. Not very stable, needs lots of debugging still it looks like.
Re: APG 4.0 beta 1
by Destiny » Fri Dec 19, 2014 11:48 pm
Hans.. Don't you mean Beta 2...
HansKeesom
Re: APG 4.0 beta 1
by HansKeesom » Sat Dec 20, 2014 12:26 am
Nope 4.0.0 beta 1... Is there already an update? Will have a look.
Re: APG 4.0 beta 1
by gkaefer » Sat Dec 20, 2014 1:01 am
Login to "my Account" go to licenses and my Upgrades and you can see the upgrade Prices...
(you can buy it actually... ;-)
HansKeesom
Re: APG 4.0 beta 1
by HansKeesom » Sat Dec 20, 2014 1:20 am
the updat prices are only if you have no license for 3.7 yet. We have no idea what things will cost when you have a license for 3.7 already. They should be less, problably 99euro for APG
Re: APG 4.0 beta 1
by Destiny » Sat Dec 20, 2014 1:23 am
That case you would have been one of the very few to actually get B1 to work..
HansKeesom wrote:Nope 4.0.0 beta 1... Is there already an update? Will have a look.
Re: APG 4.0 beta 1
by gkaefer » Sat Dec 20, 2014 1:29 am
HansKeesom wrote:the updat prices are only if you have no license for 3.7 yet. We have no idea what things will cost when you have a license for 3.7 already. They should be less, problably 99euro for APG
I have a 3.7 APG and an AVP license and my updates are listed as following (APG and AVP):
HansKeesom
Re: APG 4.0 beta 1
by HansKeesom » Sat Dec 20, 2014 1:57 am
Destiny wrote:Hans.. Don't you mean Beta 2...
Beta 2 chrashes just as easily. So it is of no use to me at the moment.
luck72
Likes: 4 posts
Re: APG 4.0 beta 1
by luck72 » Sat Dec 20, 2014 9:10 am
For me nothing yet.
APG beta 2 x64 and doesn't start!!!
Nikon D810, Nikkor 16mm fisheye,20mm, 50mm, 85mm, Amarula Bushman Tripod, Gobi panoramic Head, Windows 10/64bit, Adobe Photoshop CC 2018, Lightroom Classic CC 2018, APG 4.4.1, PTP 2.5.11
Re: APG 4.0 beta 1
by mediavets » Sat Dec 20, 2014 10:40 am
luck72 wrote:For me nothing yet.
On which OS?
Re: APG 4.0 beta 1
by gkaefer » Sat Dec 20, 2014 10:57 am
For me b2 is starting but no Menüs no icons are visible just See a blank black window.
Win 8.1 64 bit no GPU built in.
luck72
Likes: 4 posts
Re: APG 4.0 beta 1
by luck72 » Sat Dec 20, 2014 1:03 pm
On which OS?
Windows 7 pro x64
mobo AMD
The 32bit version it's working but not the 64
HansKeesom
Re: APG 4.0 beta 1
by HansKeesom » Sun Dec 21, 2014 1:42 pm
If the lack of stability stays like this, I won't even spend 79 euro and stick with 3.7.1
dang-eid
Re: APG 4.0 beta 1
by dang-eid » Mon Dec 22, 2014 12:21 am
I am also unable to get either beta to start. win7 64bit.
dang-eid
Re: APG 4.0 beta 1
by dang-eid » Thu Jan 08, 2015 4:45 pm
SOLVED for me in 4 beta 3
