First Try AutoPano Giga 4 beta 1 on OpenSuse 13.2 64bit   [SOLVED] - View the solution
atuor
by atuor » Wed Dec 17, 2014 4:10 pm
Won't start unfortunately,
AutopanoGiga> sh AutopanoGiga.sh
./AutopanoGiga: error while loading shared libraries: libicui18n.so.52: cannot open shared object file: No such file or directory
Available by default on OpenSuse 13.2 is is ver. 53 of the library -> libicu53_1
Any workaround ?
version 4 seem Great :-)
Cheers
HansKeesom
Re: First Try AutoPano Giga 4 beta 1 on OpenSuse 13.2 64bit
by HansKeesom » Wed Dec 17, 2014 11:10 pm
First glance : userinterface not changed, fortunately. My GPU is much better used and no sign of the famous last core problem. All we wait for now is the price of final version/ update price when having 3.5 already.
Me think I am using the beta for a while now. as things only seems to go faster.
Coming from a rather critical person like myself, this is good news!
....oops fist crash, ran out of memory. Guess editors are leaking again/still
and half an hour later, back to 3.7 as the beta is crashing all the time
atuor
by atuor » Thu Dec 18, 2014 7:05 am
So it launches on your OpenSuse 13.2 ? do you have libicui18n.so.52 or libicuio.so.53.1 ?
HansKeesom
by HansKeesom » Thu Dec 18, 2014 10:46 am
sorry, windows 64, did not read carefull enough
AntoineM
Re: First Try AutoPano Giga 4 beta 1 on OpenSuse 13.2 64bit  [SOLVED]
by AntoineM » Thu Dec 18, 2014 11:34 am
Hello atuor,
OpenSuse is not officially supported (Ubuntu >= 14.04 is recommended) but you can try adding these files in your AutopanoGiga folder: http://94.23.59.24/~melera/libicu.tar.gz
Best regards,
Antoine
Antoine Méler - Computer Vision R&D Engineer
atuor
by atuor » Thu Dec 18, 2014 12:32 pm
Hi Antoine,
Thanks for the files. it starts fine now. I know OpenSuse may not be supported, it has always worked fine though since I own a License of AP. I'll post feedback on it on this thread when tests go on ;-)
AntoineM
by AntoineM » Thu Dec 18, 2014 1:08 pm
Ok, thank you for your feedback !
DrSlony
by DrSlony » Sat Dec 20, 2014 2:31 pm
Hi Kolor
I have the same error on Gentoo. Saying AP is supported only on Ubuntu is an enormous mistake, for two reasons:
1- There are hundreds of distributions, Ubuntu is not necessarily the most popular nor the best, and the company that runs it certainly makes questionable ethical decisions. Supporting only this one distribution cuts out thousands of other potential Kolor clients, and is completely unnecessary, which brings me to point 2.
2- AP is not open-source, which means you provide binaries, which means you static-link during compilation. This means you could support it on any distro as long as you package all the required libs - and you do! The APG400b2 tarball comes with Qt5 libs - the only thing missing is libicui18n.so.52 so if you include that into your next tarball, it should run fine on any modern distro. :)
By the way, an up-to-date stable Gentoo uses /usr/lib64/libicui18n.so.53 not 52.
With the libs you provided in the tar.gz above, it runs fine on Gentoo :)
DrSlony
by DrSlony » Sat Dec 20, 2014 3:00 pm
DrSlony
by DrSlony » Sat Dec 20, 2014 3:27 pm
I stitched a pano, tried out everything, and no crashes here. Rock solid and very fast!
http://i.imgur.com/Hwi6g0B.jpg
atuor
by atuor » Sun Dec 21, 2014 11:31 am
I'm getting crashes when editing, maybe a graphics driver issue ? (nouveau), what settings do you use for GPU ? and what graphics card/driver do you have ?
atuor
by atuor » Sun Dec 21, 2014 11:59 am
Well yes, disabling GPU works fine now :-)
DrSlony
by DrSlony » Sun Dec 21, 2014 1:26 pm
GeForce GTX 285M, nvidia-drivers 340.65 in Gentoo 64-bit.
atuor
by atuor » Sun Dec 21, 2014 2:11 pm
Ooops, now that Beta 1 works, Beta 2 doesn't even launch...
atuor
by atuor » Sun Dec 21, 2014 6:20 pm
Yep with the Nvidia proprietary drivers it works fine (Beta 1) with GPU enabled
