Projection for Fisheye   [SOLVED] - View the solution
haplology
by haplology » Fri Oct 31, 2014 11:38 pm
Is there any way to open a fisheye image and change the projection within Autopano? I want to use the projection tools, but I don't need to stitch images - but would love to control Spherical, Panini, etc and just reproject the image.
Re: Projection for Fisheye
by mediavets » Fri Oct 31, 2014 11:43 pm
haplology wrote:Is there any way to open a fisheye image and change the projection within Autopano? I want to use the projection tools, but I don't need to stitch images - but would love to control Spherical, Panini, etc and just reproject the image.
I don't think so.
DrSlony
by DrSlony » Thu Nov 06, 2014 2:43 pm
No, but it has been requested multiple times - single image support.
Toastedcheesy
Re: Projection for Fisheye  [SOLVED]
by Toastedcheesy » Fri Nov 28, 2014 12:34 am
You can do this if you create a blank transparent image - tif,png,gif and force it into the panorama with the image you want to manipulate - There will be two images but the transparent image will not interfere with your other image - you can then change the projection method for your original image.
Dave
