[SOLVED] changing the end points of a 360 degree pano
ArtH
by ArtH » Sat May 03, 2014 5:03 am
When I stitch 360+ degree panos, autopano Giga seems to always use the first shot in the series as the center image.
Is there a way to rearrange and pick a different center (or end) image in autopano Giga so the linear 360 pano has what I want in the middle?
Re: changing the end points of a 360 degree pano
by Destiny » Sat May 03, 2014 5:08 am
Hi..
In Edit, you can use the Move Image Mode but after moving the pano click on Automatic Horizon. You can also do an offset in Photoshop after stitching and you can also change the view point in PTP..
by mediavets » Sat May 03, 2014 7:57 am
ArtH wrote:When I stitch 360+ degree panos, autopano Giga seems to always use the first shot in the series as the center image.
You can use the Vanishing Point tool in the Panorama Editor to set what you wish to be the centre of the pano.
http://www.autopano.net/wiki-en/action/ ... hing_point
ArtH
by ArtH » Sat May 03, 2014 12:33 pm
Thanks, Mediavets - that is exactly what I was looking for. Combined with the auto horizon adjust its just two clicks to a solution!
