Hot keys doesn't work
toto-foto
by toto-foto » Tue Apr 29, 2014 9:30 am
I use MacBook Pro Retina MacOS 10.9.2 + Autopano Giga 64 bits 3.5.1.
Hot key Cmd + doesn't work in Edit mode to Zoom in. But Cmd - works to zoom out.
The same thing is in CP Editor and Vertical lines editor.
Can I assign this hot keys?
Zoobius
Re: Hot keys doesn't work
by Zoobius » Fri May 02, 2014 2:53 pm
Well we didn't change anything about the zooming in/out keys, I just tried it on Mavericks and found how to do to zoom in: use Shift Cmd + keys ! Zooming out is still the same Cmd -
By the way, this is the same thing for Cmd 0 (fit on screen) and Cmd 1 (100%), you have also to use the Shift key to do it.
Guillaume - Kolor Technical Support
Quick links: User Account, Documentation, Youtube Channel
toto-foto
by toto-foto » Sat May 03, 2014 12:59 pm
Thank you, Zoobius. I'll try :)
Zoobius wrote:Well we didn't change anything about the zooming in/out keys, I just tried it on Mavericks and found how to do to zoom in: use Shift Cmd + keys ! Zooming out is still the same Cmd -
