Image size
MarcFarleyjr
Image size
by MarcFarleyjr » Mon Apr 14, 2014 9:57 pm
New to Autopano giga.
I need to resize several panos to 3300 to 6600 and 6600 to 132000 with a 2x1 format. Not sure where to start. I have changed the quality of the image but not sure how to change the size to these specifications. Does Kolor have a tutorial on this?
Thanks,
Marc
Re: Image size
by mediavets » Mon Apr 14, 2014 10:02 pm
MarcFarleyjr wrote:New to Autopano giga.
Why?
Thanks,
Marc
If you double the resolution of the image - beyond native max. resolution - you will reduce image quality.
MarcFarleyjr
Re: Image size
by MarcFarleyjr » Tue Apr 15, 2014 11:50 am
Thank you, not sure how I missed the image sizing adjustment at the top.
The reason I need to adjust the panos to a 2x1 format to meet the requirements for another software that will connect the panos. I am submitting the panos for that separate software.
I did try resizing to a 2x1 format but was unsuccessful. When I would move the scale down and then try putting in the new height, it would change the width. My minimum is 3300x6600 up to a maximum 6600x13200.
Thanks,
Marc
Re: Image size
by klausesser » Tue Apr 15, 2014 12:19 pm
MarcFarleyjr wrote:I need to resize several panos to 3300 to 6600 and 6600 to 132000 with a 2x1 format.
Hi Marc!
Can you explain this more detailed? You mean you need to up-scale an equirectangular image from 6600 to 132000px??
Please do not do this. It will be a desaster. You can´t blow up an image this much.
What do you mean "to 2x1format"?
For doing an interactive spherical image you need to render it 2:1. If you haven´t 2:1 the result will be heavily distorted.
You can crop the image-plane in the PTP-editor for having it un-distorted though it´s not 2:1.
But "resizing" it in the sense of blowing it up to x-times the size - 6600px to 132000px - means extreme interpolation due to up-scaling.
If you need the size of 132000px you need to shoot it in a way which provides the size in the stitching and rendering natively - without up-scaling by interpolation.
Re: Image size
by mediavets » Tue Apr 15, 2014 12:25 pm
MarcFarleyjr wrote:Thank you, not sure how I missed the image sizing adjustment at the top.
Thanks,
Marc
Of course, it will maintain the aspect ratio, otherwise it will induce distortion.
3300x6600 is a 1:2 aspect ratio. As is 6600x13200.
If your images do not cover the full 360x180 degree field of view when stitched, you can force a 360x180 pano FOV (which will always have a 2:1 aspect ratio) when stitching either in the Settings or in the Panorama Editor:
Re: Image size
by klausesser » Tue Apr 15, 2014 12:40 pm
MarcFarleyjr wrote:My minimum is 3300x6600 up to a maximum 6600x13200.
Then forget my previous answer . . . in your first post you wrote "6600x132000" . . . =D
