[SOLVED] How to get transparent background...
ArtH
by ArtH » Thu Apr 10, 2014 1:22 pm
I would like the background around my finished panos to be transparent rather than black. I export them as 16 bit TIFF's for editing in Photoshop, so it should be possible.
I've searched documentation and settings and find nothing about altering the background, but as a new user I am probably missing something obvious. I can (and have) removed the background in photoshop - but would really rather avoid that, as any blacks that touch the edge must be hand-retouched.
Any advice is welcome! Thank you.
Re: How to get transparent background in TIFF rather than Bl
by klausesser » Thu Apr 10, 2014 1:53 pm
ArtH wrote:I would like the background around my finished panos to be transparent rather than black. I export them as 16 bit TIFF's for editing in Photoshop, so it should be possible.
Export them as .PSD or .PSB or as layers. UNCHECK "remove Alpha channel".
ArtH
by ArtH » Thu Apr 10, 2014 2:30 pm
Thanks! Makes perfect sense. I'll give that a try tonight.
