"Multiple Viewpoints" in 3.5
rmark
Re: "Multiple Viewpoints" in 3.5
by rmark » Mon Apr 07, 2014 1:59 pm
I will continue to use 3.0. Is 3.0 available to new customers?
AntoineM
by AntoineM » Mon Apr 07, 2014 2:20 pm
rmark wrote:Thank you. I understand the model difficulties. But I must point out that 3.0 did have one-checkbox (Multiple Viewpoints) that produced very good results!
I have been using 3.0 successfully for a long time, on multiple viewpoint projects in addition to the air-photos cases.
I don't know what settings the Multiple Viewpoints box used, but can it be brought back? It is the reason that I have recommended your software to so many others, in person and in publications.
Ok rmark, I understand, we are going to think about bringing back a simple multiple viewpoints checkbox in the new 3.5 engine.
Regards,
Antoine
by mediavets » Mon Apr 07, 2014 2:25 pm
rmark wrote:I will continue to use 3.0. Is 3.0 available to new customers?
Yes.
http://www.kolor.com/download-previous-version.html
rmark
by rmark » Mon Apr 07, 2014 2:28 pm
Thanks.
by gkaefer » Tue Apr 08, 2014 5:43 pm
If 3.0 works for you why not stick with it?
but (besides the availability question of 3.0 version...) this is not really the question?
A new Software does get released with something in mind... less Errors, maybe more Features, hopefully better workflow and faster result. But it should not be the scope top make a one click Radio Option Settings complicated so nobody can find it anymore, erase the Options Name and replae it with a full set of 9 Options with 24 single values which you can randomly mix with same bad result hoping to find the one outer giving you the working pano finally.
And yes I understand that the aereal Images are Special cases. but the success Story suggests apg can handle this... and past (3.0) Version could easily handle These Images too....
@ Antoine: using your Settings from screenshot gives me still no "somehow fitting" pano (even trying all projections)
pablorg
by pablorg » Wed Jun 04, 2014 6:50 pm
I have the same problem. I tried the 2.6 trial and it will stitch my aerial photographs with multiple viewpoints no problem.
I bought a license, hoping to be able to export the stitched image but alas a new license does not work with autopano giga 2.6
I get this error message: "Registration failed. The licence you have is obsolete. You need to update your registration code. Go to your account here : http:////www.kolor.com//magento-support// to get a new licence.""
Can somone help?
by mediavets » Wed Jun 04, 2014 7:04 pm
pablorg wrote:I have the same problem. I tried the 2.6 trial and it will stitch my aerial photographs with multiple viewpoints no problem.
Can somone help?
Welcome to the forum...
A previous post in this thread suggest that v 3.0.x works as well.
You could use your 3.5.x key with that version which you can obtain here:
http://download.kolor.com/apg/stable/history
pablorg
by pablorg » Thu Jun 05, 2014 2:38 pm
Thanks, i did install 3.0 however, the stitching does not work as well as 2.6, it seems. I can't be fully certain because the errors are most apparent at higher resolution. Since I cannot render from the 2.6 trial, i can't see at too high a resolution, but in the control points editor, it seems 2.6 stitches correctly, while 3.0 does not.
Previous
