360 with 8mm sigma problem
sundust
by sundust » Thu Apr 03, 2014 8:02 am
Hi there I have a problem with my sigma 8mm lens. it is the first time I used a fisheye.
The onlything I didnt had was a panoramic head.
What ever I do I cant get perfect solution Mostly the lines of ceiling are broken I have uploaded a sample (Source images, images of the Autopano setup and the result) to my web page.
Where did I go wrong. Please help me.
Here is the set up:
Canon 5D MIII
Sigma 8mm fisheye
Tripod with no panoramic head
Autopanogiga 3.0.8
files: http://www.tripodmedya.com/problem.rar
Re: 360 with 8mm sigma problem
by mediavets » Thu Apr 03, 2014 8:22 am
sundust wrote:Hi there I have a problem with my sigma 8mm lens. it is the first time I used a fisheye.
Here is the set up:
Canon 5D MIII
Sigma 8mm fisheye
Autopanogiga 3.0.8
What did you do wrong?:
You didn't use a pano head.
You didn't have the camera/lens set at the NPP; with your camera/lens combination this should be oissble without a proper pano head if shooting just a single row of 3 or 4 images. with a small positive pitch.
You are using APG 3.0.8 and not 3.5.
You are not using the ideal fisheye lens for your camera.
You would do better with a proper pano head and a fullframe (as opposed to a circular) fisheye lens.
sundust
by sundust » Thu Apr 03, 2014 8:32 am
Sorry but what is NPP?
by mediavets » Thu Apr 03, 2014 8:37 am
sundust wrote:Sorry but what is NPP?
No Parallax Point - so that the camera/lens rotates around the entry pupil of the lens.
A proper pano head allows you to set your camera/lens at the NPP for multirow shooting.
If you are just shooting a single row then it should be possible using a simple rail on your tripod which allows fore/aft adjustment of camera/lens.
It is essential for the camera/lnes to be at the NPP whee shooting interiors with fisheye lenses, otherwise you can never achieve a perfect stitch.
http://www.johnhpanos.com/epcalib.htm
sundust
by sundust » Thu Apr 03, 2014 8:48 am
ok thanks
