APG newbie…
jarane
APG newbie…
by jarane » Mon Mar 31, 2014 1:44 pm
Hi everyone,
I'm trying to migrate from PTGUI to APG, in order to be able to use Livepano, and am having a really hard time doing it.
I shoot a Nikon D800 on a 360Precision Absolute head. 6 shots at -15º + Zenith.
On APG I add the 7 images, click on "detect" and the results are horrifying!!! (attached image).
I have watched most video tutorials online and read the online docs, but nothing seems to address this situation.
Is there a specific setting for shooting at -15º?
Any help is welcomed
Thanks in advance,
E.C.
Re: APG newbie…
by mediavets » Mon Mar 31, 2014 2:21 pm
jarane wrote:Hi everyone,
Thanks in advance,
E.C.
Perhaps the EXIF is missing from your images and APG does not recognise your lens focal length or lens type (fisheye).
Check Image properties and change lens type if necessary, also check the crop circle:
jarane
Re: APG newbie…
by jarane » Mon Mar 31, 2014 2:39 pm
Thanks media vets,
all the exif data is recognized by APG but somehow it renders this weird result.
What else do you think it could be?
Thanks again,
E.C.
Re: APG newbie…
by AlexandreJ » Mon Mar 31, 2014 2:42 pm
This is probably due to some wrong links because of pattern matching.
Look at this tutorial : http://www.autopano.net/wiki-en/action/ ... n_I_do_%3F
Re: APG newbie…
by klausesser » Mon Mar 31, 2014 3:34 pm
Thanks in advance,
E.C.
Hi!
I guess you´re using the 2,8/16mm Nikon Fisheye? Nevertheless set the values to "Fisheye" in the APG´s prefs. I realized that the 16mm sometimes gets not recognized correctly.
You don´t need a dedicated setting for -15° - i also use to shoot this way.
jarane
Re: APG newbie…
by jarane » Mon Mar 31, 2014 6:45 pm
Thanks guys,
I tried all of your suggestions and, although it went from nothing to very good, it still needs work.
Since I don't know the interface, it's hard for me to fine-tune the Zenith to perfection.
What I did, was to save the project as a template and applied it to a new project with the same images. Then I repeated the whole process, but it didn't seem to improve it.
I'm attaching a screen capture of the pano, and of one of the problem areas.
How can I improve the stitching?
Also, is there any way to improve the RMS of the Control Points?
@ Klaus: do you also shoot 6 x -15º plus Zenith at 90º?
Thanks again,
E.C.
Re: APG newbie…
by mediavets » Mon Mar 31, 2014 7:04 pm
jarane wrote:Thanks guys,
Thanks again,
E.C.
A lot of relatively featureless space.
The type of scene that may cause APG's auto control detection problems.
Have you yet explored the Control Points Editor?
http://www.autopano.net/wiki-en/action/ ... nts_Editor
jarane
Re: APG newbie…
by jarane » Mon Mar 31, 2014 7:15 pm
Yes,
I followed Alexandre's suggestion and applied all the steps of the linked tutorial to my images.
The files generated by the D800 have a ton of information, and you can easily see creases, holes and every stain on the white walls (unfortunately so, hehe).
When trying to generate CPs to the problem areas, I realized that their RMS was getting increasingly higher. There must be a way to optimize those CPs to make them usable.
Do you know if it's possible?
Thanks,
E.C.
Re: APG newbie…
by klausesser » Mon Mar 31, 2014 7:17 pm
jarane wrote:@ Klaus: do you also shoot 6 x -15º plus Zenith at 90º?
I shoot 5 @ -12° + Zenith. 20% overlap. Nikon D800, Nikon 2,8/16mm, Panoneed head.
Re: APG newbie…
by mediavets » Mon Mar 31, 2014 7:21 pm
jarane wrote:When trying to generate CPs to the problem areas, I realized that their RMS was getting increasingly higher. There must be a way to optimize those CPs to make them usable.
Thanks,
E.C.
See: http://www.autopano.net/wiki-en/action/ ... _RMS_value
Re: APG newbie…
by AlexandreJ » Tue Apr 01, 2014 8:28 am
One note: you should definitively try the version 3.5 where we made a lot of improvement in out-of-the-box quality stitching.
Re: APG newbie…
by klausesser » Tue Apr 01, 2014 2:36 pm
AlexandreJ wrote:One note: you should definitively try the version 3.5 where we made a lot of improvement in out-of-the-box quality stitching.
Yes - i definitely agree!
jarane
Re: APG newbie…
by jarane » Tue Apr 01, 2014 3:24 pm
I'm giving 3.5 a try, but there is something weird about it.
Even though all the images are loaded, APG 3.5 does not see the Zenith (image attached).
Following your suggestions for APG 3, my settings are:
General:
default
Images:
in no EXIF data Use 16mm Fisheye
Detection:
default
Optimization:
local/global checked. all else unchecked.
Panorama:
default
Render:
default
Re: APG newbie…
by AlexandreJ » Tue Apr 01, 2014 5:03 pm
look at your group properties. The focal length indicates 16mm. Or these images are 16mm fisheye. Just change that with the (i) icons and everything will work:
http://www.autopano.net/wiki-en/action/ ... eye_images
