[SOLVED] Can you manually add links?
Holeycow
by Holeycow » Sun Mar 30, 2014 1:28 pm
Hi, I'm only new to this software and was wondering if there is a way to manually force Autopano to accept two images being linked when it doesn't automatically give the option. I would have thought it to be an obvious feature,. but have been unable to find anything in the documentation to help me out. I go into the control points editor, and it seems that the the only link options it gives you are what it detects itself.
Re: Can you manually and links?
by mediavets » Sun Mar 30, 2014 2:32 pm
Holeycow wrote:Hi, I'm only new to this software and was wondering if there is a way to manually force Autopano to accept two images being linked when it doesn't automatically give the option. I would have thought it to be an obvious feature,. but have been unable to find anything in the documentation to help me out. I go into the control points editor, and it seems that the the only link options it gives you are what it detects itself.
Welcome to the forum...
See: http://www.autopano.net/wiki-en/action/ ... trol_point
Holeycow
by Holeycow » Sun Mar 30, 2014 11:25 pm
Thank you.......I get it now.
