Read this before posting - Forum rules
by Annis » Thu Mar 27, 2014 4:23 pm
This sub-forum is for users looking for a better way to solve a specific panorama case, or just looking for basic instructions.
Do not post any bug reports, stability issues, crash reports, etc. - use the Bug Report forum for those.
Before asking for technical support, have a look at our Documentation and Video tutorials.
When posting, make sure that you provide as much information as possible:
- Your computer specs
- Your camera, lens used
- Which version of the software you are using
- How many images, what file format
- Screenshots, we love those
- etc..
Once the issue is solved, check the solved button on the top right corner of the post that provided you with the solution.
Make sure you post one topic per issue, so that they can be dealt with separately.
Thanks for reading.
cheezles likes this post.
