Lens Profile after stitching
gregdowning
by gregdowning » Wed Mar 12, 2014 3:07 am
I stitched a pretty elaborate pano and the vignette was pretty strong so I decided to try the adobe lens profile. I was able to find where you can import the profile before detecting but there didn't seem to be a way to add the profile after stitching. Do you have any advice for me? I spent a week on this image so don't really want to start over.
Liked in: 227 posts
Re: Lens Profile after stitching
by Destiny » Wed Mar 12, 2014 4:26 am
Hi... Did you capture your images in RAW?
gregdowning
by gregdowning » Wed Mar 12, 2014 7:31 pm
I captured in RAW but I am processing jpegs at 100%
Liked in: 227 posts
by Destiny » Wed Mar 12, 2014 9:54 pm
Well, thats good... If you have access to CS6 Camera RAW, it has some really nice lens profiling options and it works.. You can still export as jpgs but I would suggest TIFs.. APG also has a Vignette plugin which works to a degree.. It really depends on your lens and the Fstop you used as to how much vignette has occurred...
