Can you pitch a 360 pano 90degrees, fix it in PS and bring i
Bmachine
by Bmachine » Tue Feb 25, 2014 2:15 am
I have a 360 / 180 pano where I forgot to shoot a nadir shot. When I assemble it in APG, it gives me empty pixels all along the bottom.
If I use the pitch tool at 90 degrees, this empty area comes up as a much smaller roundish patch in the middle of the pano. I would like to be able to render that, export it to Photoshop for fixing and painting and then somehow, reset the pitch back to 0 degrees so I end up with a "normal" 360 pano that I can bring into Panotour.
Is there a way to do that?
Thank you
Bo
Re: Can you pitch a 360 pano 90degrees, fix it in PS and bri
by mediavets » Tue Feb 25, 2014 11:07 am
Bmachine wrote:I have a 360 / 180 pano where I forgot to shoot a nadir shot. When I assemble it in APG, it gives me empty pixels all along the bottom.
Thank you
Bo
See: viewtopic.php?f=33&t=21629&p=138120#p138120
Bmachine
by Bmachine » Tue Feb 25, 2014 6:39 pm
Thank you mediavets.
Bo
