Problem with stitching - 8mm fisheye lens
sander
by sander » Mon Feb 17, 2014 7:30 pm
Hi all,
Today I bought a Samyang 8mm fisheye lens to use with my Canon 60D and panoramic head. When stitching the pictures (6+one up and one down) I get a strange result. It looks like a line around each photo. Also, the EXIF data says the focal length is 80,1mm (50mm, cropped). This is the (weird) result:
I tried some change in the settings (like choosing the fisheye function) but that made it only worse. The software worked fine with my Canon 10-22 lens.
I hope someone can help... Thanks!
Re: Problem with stitching - 8mm fisheye lens
by mediavets » Mon Feb 17, 2014 7:43 pm
That Samyang lens has no electrical connection to the camera body - so no EXIF data.
You will have to set the focal length manually in image properties.
Choose a setting of 9mm for focal length and fisheye for lens type; checking the Crop circle.
Alternatively you can change the global settings for no-Exif images.
sander
by sander » Mon Feb 17, 2014 8:12 pm
Thank you so much! Looks great after changing these image settings!
