please help stitching issues
verticalpoint360
by verticalpoint360 » Mon Feb 03, 2014 2:07 pm
trying to stitch 3 images together using 8mm fisheye on nikon D4, has been going well and suddenly this is happening? the camera seems to be set up as best a possible, nodal, etc is all in line.
Re: please help stitching issues
by mediavets » Mon Feb 03, 2014 2:15 pm
Two comments:
1. You seem to be using a rather old version of APG - 2.5.2.
You might like to try the new APG 3.5 beta 1?
2. If you'd like to make the images available for download as a ZIP file I'd be happy to take a look.
verticalpoint360
by verticalpoint360 » Mon Feb 03, 2014 2:21 pm
Hi thansk for reply - trouble is I'm at the location with little internet. this is what is happening now.
by mediavets » Mon Feb 03, 2014 2:28 pm
Check the Group image properties and Crop circle as a first step.
Also Group settings.
verticalpoint360
by verticalpoint360 » Mon Feb 03, 2014 2:30 pm
these are the example files I'm struggling to stitch.
by mediavets » Mon Feb 03, 2014 2:34 pm
Have you removed both parts of the lens cap?
There is a flat front section and also a ring around the lens barrel.
You need to remove both.
verticalpoint360
by verticalpoint360 » Mon Feb 03, 2014 2:50 pm
Briliant thank you so much! cant believe I've missed that! not familiar with the lens at all, only used once. one other thing, the nodal is dead centre in the camera view finder but it all seems out, what do you think?
by mediavets » Mon Feb 03, 2014 2:57 pm
verticalpoint360 wrote:Briliant thank you so much! cant believe I've missed that! not familiar with the lens at all, only used once.
I think most new owners of the Sigma 8mm FE lens fall into that 'trap' when first shooting panos - I know I did back in the day.
See: http://www.easypano.com/forum/display_t ... picID=4162
It may help.
Camera sensors are often not perfectly centred.
verticalpoint360
by verticalpoint360 » Mon Feb 03, 2014 3:08 pm
Great thanks a bit of trial and error by the look of it. thanks again for your help as always, much appreciated!!
