templates don't save roll settings
suoloco
by suoloco » Sun Jan 19, 2014 10:44 pm
Thanks for your work and time.
Am I wrong or templates are supposed to save roll settings?
Please say something...
John360
Re: templates don't save roll settings
by John360 » Mon Jan 20, 2014 11:55 pm
Im not sure what you mean by template but I believe you talk about settings in the preview window? There is a "set default view" to save settings.
by mediavets » Tue Jan 21, 2014 9:36 am
John360 wrote:Im not sure what you mean by template but I believe you talk about settings in the preview window? There is a "set default view" to save settings.
He is talking about this option in APG 3.x:
John360
by John360 » Mon Jan 27, 2014 1:34 pm
hehe. Must have been tired :)
suoloco
by suoloco » Mon Jan 27, 2014 8:36 pm
Sorry for the delay. Thanks for your answers.
APG can save the project as a template. "Autopano saves the links used to create the panorama within a template. This can then be used to create new panoramas with the same configurations.To re-use a model, you need to specify it in the Group settings (Detection tab) before launching the panorama’s detection."
Ok, I understand templates takes the links, but what about the other tool setting of the panorama editor, as yaw, pich, roll… Are they included in the template?
All the panos I shot needs the same roll correction (about -0,7) so it would be great save a template with this roll setting instead of fix it one by one. Beside, the auto crop function would be apply over the template, hence it'd do a better job.
by mediavets » Mon Jan 27, 2014 9:39 pm
suoloco wrote:Ok, I understand templates takes the links, but what about the other tool setting of the panorama editor, as yaw, pich, roll… Are they included in the template?
Don't know, but have a look - template files are plain text I think.
