converting equirectang to cylindrical projections
verticalpoint360
by verticalpoint360 » Fri Jan 17, 2014 10:08 am
Hi - A client has asked if i can limit the projection angle on a 360 spherical tour I've already produced, he basically doesnt want it to go up and down, just rotate 360 vertically. Can this simply be done in Panotour or do i need to rebuild the original files in autopan Giga (as a Cylindrical). I did just try cylindrical in autopan but it produced this?
Thanks to all
Liked in: 129 posts
Re: converting equirectang to cylindrical projections
by mediavets » Fri Jan 17, 2014 10:30 am
verticalpoint360 wrote:Hi - A client has asked if i can limit the projection angle on a 360 spherical tour I've already produced, he basically doesnt want it to go up and down, just rotate 360 vertically. Can this simply be done in Panotour or do i need to rebuild the original files in autopan Giga (as a Cylindrical). I did just try cylindrical in autopan but it produced this?
Thanks to all
Yes; simply use the Crop tool in the Hotspot editor panel in PT/PTP to limit the viewable area of the pano.
verticalpoint360
by verticalpoint360 » Fri Jan 17, 2014 10:36 am
awesome thanks Mediavets, this forum is great thanks to guys like you!!
Liked in: 129 posts
by mediavets » Fri Jan 17, 2014 10:46 am
verticalpoint360 wrote:awesome thanks Mediavets, this forum is great thanks to guys like you!!
You have to apply the desired Crop (it's a virtual crop it doesn't actually change the image) to each pano for which you wish to limit the viewing area - it's not a global setting.
verticalpoint360
by verticalpoint360 » Fri Jan 17, 2014 10:50 am
cool all noted thanks mate
