Editing control points in HDR stacked panoramas
jasonkimmings
by jasonkimmings » Wed Jan 15, 2014 4:16 pm
Hi. Can someone walk me through exactly how to do this?
- I have taken a panorama using an auto bracket sequence (say -1, 0 and +1 ECV).
- I open APG and put them into stacks (for some reason it never auto detects it, even though it was auto on the camera).
- I detect the panorama.
Now is the potential problem. I need to edit control points in the panorama. How do I do this and have it update all three layers/stacks? I'm sure it's simple but I can't find reference to it anywhere. And what setting would I use to do this and then what render settings would I use? Anti-ghosting or Exposure Fusion? Both sound like what I want!
Thanks,
Jason
Re: Editing control points in HDR stacked panoramas
by mediavets » Wed Jan 15, 2014 5:59 pm
jasonkimmings wrote:Hi. Can someone walk me through exactly how to do this?
Use hard links in the stack and detect links on reference layer only: see screenshot below.
Thanks,
Jason
[/quote]
Use exposure fusion.
+/-1 EV is seldom enough to have much effect.
Rontrus
Which bracket to choose for controll points? Superimposabili
by Rontrus » Thu Jan 16, 2014 5:59 pm
I've followed these instructions succesfully (for I had the same problem as jasonkimmings), but unfortunately Autopano chooses the darkest exposure bracket for setting controll points, so they are hard to confirm or to reposite. Can I determine which bracket to use for controll points?
Second issue: Though I proceeded like described above and only one bracket got controll points, the different layers sometimes showed little differences in output and were superimposable only at first glance. I never experienced this using Hugin.
Cheers,
Wolfgang
Re: Which bracket to choose for controll points? Superimposa
by mediavets » Thu Jan 16, 2014 6:19 pm
Rontrus wrote:Hi,
Welcome to the forum...
Yes, you can you can select the index level which will be used for CP detection - see screenshot 1
Cheers,
Wolfgang
Why are you generating separate layers? If you do that antighost cannot operate can it?
As I understand it the seams will/may vary in different layers due to the way APG works.
Rontrus
by Rontrus » Sat Jan 18, 2014 2:24 pm
mediavets wrote:Welcome to the forum...
Thank you!
Ah, I think that's it; thanks!
I'm not sure if I had enabled "antighost" that time, but how can there be differences anyway, when only one set of controll points exist? All the shots were taken with a (stable) tripod and mirror pre-release. The single images match perfectly.
I prefer to output exposure-layers and process the images in photomatix, for I just own APP, not APG :)
Cheers
Wolfgang
by mediavets » Sat Jan 18, 2014 2:32 pm
Thank you!
There can be differences if you don't hard link stacks; and also I think if you output layers using Antighost that algorithm may place seams differently in different layers?
Cheers
Wolfgang
I believe that most people who process bracketed exposures outside APP/APG prefer to do it with Photomatix (or another third-party program) before stitching.
HansKeesom
by HansKeesom » Sat Jan 18, 2014 2:44 pm
Even when not using stacks it can be usefull to process them in photomatix. I converted 1000 raw to tiff with some CA correction and compression and had a much better stich result.
