From raw pano to final editing in Lightroom, best workflow?
SpAiK
by SpAiK » Tue Jan 07, 2014 1:06 pm
Hi! First time here and first post :) I've recently been in NYC and have taken some panoramas. I usually work with Lightroom for correction as I'm used to it and it's simplicity, so now I want to stich my panos from raw source and keep all the data to then make final editing in LR. But I don't know what is the best way to go, should I color correct in HDR and export in tiff16? Should I use ghost removal or fusion?
Re: From raw pano to final editing in Lightroom, best workfl
by mediavets » Tue Jan 07, 2014 2:39 pm
SpAiK wrote:Hi! First time here and first post :) I've recently been in NYC and have taken some panoramas. I usually work with Lightroom for correction as I'm used to it and it's simplicity, so now I want to stitch my panos from raw source and keep all the data to then make final editing in LR. But I don't know what is the best way to go, should I color correct in HDR and export in tiff16? Should I use ghost removal or fusion?
Welcome to the forum...
What camera and lens did you use?
Did you use a proper pano head?
Are you using bracketed exposures?
Did you shoot 360 HFOV?
Multirow or single row?
SpAiK
by SpAiK » Tue Jan 07, 2014 5:00 pm
I used a Canon 550d with stock 18-55mm without panohead, all shoots were handheld and no bracketing. There are some 360hfov panos and some shorter, single row all.
by mediavets » Tue Jan 07, 2014 5:44 pm
SpAiK wrote:I used a Canon 550d with stock 18-55mm without panohead, all shoots were handheld and no bracketing. There are some 360hfov panos and some shorter, single row all.
If single exposures then use anti-ghost. Fusion relates to bracketed exposures.
Many people would recommend doing RAW conversion before stitching.
SpAiK
by SpAiK » Tue Jan 07, 2014 10:07 pm
What about color correction?
mediavets wrote:Many people would recommend doing RAW conversion before stitching.
I thought it would be better to load raws directly and mount the panorama before starting to work on image correction.
by mediavets » Tue Jan 07, 2014 10:10 pm
SpAiK wrote:What about color correction?
Use the default settings in APG to start with.
Well...try and see.
UK Pano
by UK Pano » Wed Jan 08, 2014 12:20 pm
export RAW to TIFF to stitch in APG > Stitch in APG and export as TIFF again > import stitched TIFF into LR for tweaks > export from LR to final JPG
SpAiK
by SpAiK » Wed Jan 08, 2014 9:53 pm
So that way the dynamic range of the originals would be preserved (at least most of it) through all the process?
UK Pano
by UK Pano » Fri Jan 10, 2014 10:29 am
yes as non-destructive/uncompressed (as JPG gives) from the RAW image by using 16bitt tiff
