Result in LDR/Auto too bright
radeldudel
by radeldudel » Mon Dec 30, 2013 7:21 am
I've got a simple panorama made of 13 pictures in one row.
Even though I've shot the images in manual mode the brightness of the sky changes in a few of the pictures, so I need to use the LDR color correction to correct the sky.
My problem is: The pano renders way too bright if I activate Auto/LDR. And I'm too blind to see how I deactivate the gamma correction of the overall brightness. I tried to set another image as anchor but it didn't change the brightness.
I probably just miss something to click on to deactivate overall gamma, don't I?
My version is 3.0.8
Cheers Sam
Re: Result in LDR/Auto too bright
by mediavets » Mon Dec 30, 2013 9:17 am
radeldudel wrote:I've got a simple panorama made of 13 pictures in one row.
My version is 3.0.8
Cheers Sam
You can adjust gamma here:
