mediavets wrote:My contention is that when the product is named Autopano and makes great play of the auto aspect then one should not have to 'play' with it.
lumelix wrote:mediavets wrote:My contention is that when the product is named Autopano and makes great play of the auto aspect then one should not have to 'play' with it.
Hi mediavets
Yes, you can understand the "Auto" in Autopano like this way.
On the other side, then you shouldn't play also with a DX lens on an FX sensor.
If I look at the CPs with the 16mm FE it's really ok. With this lens you shoot a zenith image and don't use the extreme corners. Then it's better to use these "centered" CPs.
APG and pano shooting is much too versatile in order to find a simple solution for all cases, isn't it ?
lumelix wrote:HansKeesom wrote:[Don't want to sound arrogant, but in my mind people should have to understand the basic meaning of the terms/words they use when communicating
Hi Hans
Some photographers are more technicians, others are more artists
One of the best photographers I know has no idea of technical terms. But he has a heart for his motives.
mediavets wrote:I drive a car with an auto gearbox - I don't then expect to have to change gear manually.
HansKeesom wrote:My experience with artists is that they absolutely know what they are talking about, at least the succesfull ones
HansKeesom wrote:Whatever someone is, if you use terms you should at least have a basic understanding of them , otherwise you are just a charlatan.
lumelix wrote:HansKeesom wrote:Whatever someone is, if you use terms you should at least have a basic understanding of them , otherwise you are just a charlatan.
Ok. I know some very very succesfull charlatans!
Mastermedia wrote:Dear friends,
I am new to autopano pro and giga. I I started working on This software due to the fact that my cameraman abandoned me in the middle of a project. A VERY IMPORTANT one. I have tried to stitch the images so many times and read, view videos and no solutions found.
I would like to know if any of you could help me get this panoramas stictched so I can create the virtual tours with panotour. My deadline is in 3 days and im starting to panic. Can anyone PLEASE help?
You can write me to info(at)kennysilva.com It will be greatly appreciated.
Kenny
