Portable version of AutoPano possible?
Pipetman
by Pipetman » Tue Jun 19, 2007 3:33 pm
I'm switching computers fairly often or re-install my OSes on a regular basis. Thus, I really like programs, that don't require an installer and give you the option to write settings into an ini file instead of the registry. That also makes it possible to run these programs e.g. from a USB stick or an external hard drive.
I was just wondering, if it would be possible to make Autopano portable? It won't make or brake my decision to buy AP1.4 (once it's out), but it would be a nice thing to have. Thx.
by AlexandreJ » Tue Jun 19, 2007 3:55 pm
There are standard ways to transform a software into a portable version. This can be done easily : thinstall is a tool to do it.
Pipetman
by Pipetman » Thu Jun 28, 2007 9:02 pm
Hm, a Thinstall license is $5000 and they seem to target the corporate market. Other ways of making applications portable are not exactly trivial and involve things like AutoIT scripting etc...
by AlexandreJ » Fri Jun 29, 2007 7:44 am
The other option is to have a switch for launching autopano via command line that says to use .ini files instead of registry. It's enough to get a portable version. Oh no, except one part : microsoft crt libs 8.0 ... they need to be installed in the system.
KingOfNuls
by KingOfNuls » Wed Feb 25, 2009 12:06 am
How to do this? Is it actually possible? I'd like to "autopano" on all the computer i could use, and my USB key go everywhere with me.
by AlexandreJ » Wed Feb 25, 2009 8:31 am
I will add that to the todo list. A switch in command line to use an .ini file on windows to store settings instead of the registry.
KingOfNuls
by KingOfNuls » Wed Feb 25, 2009 7:17 pm
Thanks a lot.
Pipetman
by Pipetman » Mon May 18, 2009 3:33 pm
I just upgraded to the new AP 2.0.1 (quite an exercise, as I was confronted solely with websites in French to buy the new license) and - as far as I can tell - it seems like the portable feature didn't make it into the new version.
A bit disappointing, as this was one of the major reasons for me to upgrade. Anyone have an update, if we can expect this anytime soon?
Thx
by mediavets » Mon May 18, 2009 3:59 pm
Pipetman wrote:and - as far as I can tell - it seems like the portable feature didn't make it into the new version.
Thx
What 'portable feature' is that?
Pipetman
by Pipetman » Mon May 18, 2009 5:16 pm
<quote>What 'portable feature' is that?</quote>
'portable feature' is maybe not the best way to put it, but as mentioned further up, it's simply the possibility to run APP in a portable mode (e.g. from a USB stick, having all settings in an ini or xml file (instead of the registry) and allowing for relative paths definitions etc.)
phototrek
by phototrek » Mon May 18, 2009 5:31 pm
Hmm, I always just drag & dropped the app and ran it from pretty much any location I could think of...
iMac 27"
Canon Equipment
Pipetman
by Pipetman » Mon May 18, 2009 6:44 pm
Hmm, that might work on a Mac (?), but certainly not on a Windows machine.
DrSlony
by DrSlony » Mon May 18, 2009 10:10 pm
Settings and reg info will be lost thats why they want a portable version that doesn't use the registry.
