Serious vignetting issue
Track
by Track » Sun Sep 22, 2013 5:04 pm
This is more of a general photography question, but it's not noticeable in just one shot. You only really see it when stitched.
I was shooting 300mm with my Canon 75-300 f/5.3 lens and I didn't notice until I saw it in the preview, but the panorama is basically ruined.
What caused this?
lumelix
by lumelix » Sun Sep 22, 2013 5:15 pm
Hi Track
You are working through all possible errors you can do when shooting panoramas ;)
This is clearly vignetting from your zoom lens. You can see it also when move two images
one above the other e.g. in Photoshop.
Zoom lenses aren't first choice for shooting panoramas because most of them have a lot of vignetting.
You can try to correct the vignetting of the single images with Canon Software or Photoshop. The result will be better after this.
Regards
Martin
Track
by Track » Sun Sep 22, 2013 6:57 pm
lumelix wrote:Hi Track
Haha. Yes. Thus is the process of learning :)
lumelix wrote:Zoom lenses aren't first choice for shooting panoramas because most of them have a lot of vignetting.
That might be true, but finding a 300mm prime lens is impossible for a decent price.
Besides, I've shot 300mm plenty of times, sometimes even with a 2x adapter (600mm), and I've never had a single issue..
lumelix wrote:You can try to correct the vignetting of the single images with Canon Software or Photoshop. The result will be better after this.
I've tried, but the result is never as good as I would like..
How come this only started happening right now?
lumelix
by lumelix » Sun Sep 22, 2013 11:53 pm
Track wrote:How come this only started happening right now?
Perhaps you have shooted with open aperture or with a wrong lens hood?
Btw: There are some used and cheap (around 800$ up) EF 300mm 4L USM f/4 teles in ebay.
With this fixed lenses you get better results at 300mm as with the zoom an converter at 600mm!
And with much less pictures ;)
Regards
Martin
Track
by Track » Mon Sep 23, 2013 1:36 am
Well, I do have a Sigma 150-500mm lens. It cost me 1,000$.
con
by con » Mon Sep 23, 2013 9:36 am
Quite simply correct the vignetting by using lens correction parameters in Photoshop or Lightroom (or whatever suits) - then you'll start stitching with clean jpgs.
I'd also have a closer look at blending options as this would have quite a different results I'd imagine.
by gkaefer » Mon Sep 23, 2013 10:11 am
or use the plugin in apg...
renan
by renan » Mon Sep 23, 2013 10:26 am
I'm interested by having your pictures as case study.
If you can upload them :
http://www.kolor.com/forum/t766-ftp-server
Track
by Track » Mon Sep 23, 2013 11:08 am
renan wrote:I'm interested by having your pictures as case study.
It's a big panorama - 126 pictures. You want all of them or just a section?
Also, if someone has a tutorial on how to perform lens correction via Photoshop, I'd appreciate it.
renan
by renan » Mon Sep 23, 2013 12:09 pm
Track wrote:It's a big panorama - 126 pictures. You want all of them or just a section?
Just a part can be useful. May be with one .pano file to exactly reproce this blend.
Thanks.
con
by con » Mon Sep 23, 2013 9:38 pm
Track wrote:Also, if someone has a tutorial on how to perform lens correction via Photoshop, I'd appreciate it.
PS CS5
Filter> Lens Correction>
and then from in there find your lens from the list and it should have defaults to remove vignetting and pin cushion effect ascociated with that lens, you can also manually increase the effect using sliders etc. Its all pretty intuitive
lumelix
by lumelix » Mon Sep 23, 2013 11:02 pm
Next lesson: Use GOOGLE!
http://www.youtube.com/watch?v=0kTXtwBaq-I
Regards
Martin
