Gigapixel calculation problem
pranshu14
by pranshu14 » Fri Aug 16, 2013 5:36 am
Hello
I have 1456 images of a cityscape and i am creating a gigapixel view.
The issue is the last time I imported the images into autopano giga
it was showing me the final outcome will be 18 gigapixel
but after reimporting those images it is now showing the final size is 12 gigapixel.
Why this change is happening ???
the first import has direct from the camera (jpg) imgs
the second import was imgs with color correction in LR and then imported to the APG
but in both the cases the resolution of the imgs were same.
Then why the final outcome size is changing every time ??
Christian Stüben
Likes: 3 posts
Liked in: 9 posts
by Christian Stüben » Fri Aug 16, 2013 8:29 am
Your pano 18gp shows straight borders, the second does not. Did you do a cropping on the first and not yet on the second?
greetings from germany
Chris
Last edited by Christian Stüben on Fri Aug 16, 2013 8:31 am, edited 1 time in total.
pranshu14
by pranshu14 » Fri Aug 16, 2013 10:26 am
First is after cropping 18 GP but second is without crop 13GP
on crop it is coming upto 12 GP.
Artisan New
by Artisan New » Fri Aug 16, 2013 9:49 pm
What was the shooting pattern.....pattern + overlap + size settings in the render page determins the maximal final outcome. The actual outcome depends on a lot of things. Not all of these are cristaline I'm affraid, since these are programmed using recursive algorithms and these tend to have some life of their own.
Greets, Ed.
Olympus OM-D with HLD-6, Fuji GX680, Samyang 7.5, Olympus 9-18, Sigma 19, Panasonic 14-45, Nikon 50 1.4 on Novoflex with tripod mount, Nikon 80-200, Panasonic 45-200, Fujinon 135, Fujinon 80, Fujinon 65, Fujinon 50, Gitzo Gilux Reporter 2, Sirui Ballhead and Panosaurus 2.0 NNP adapter, Motorized Panohead of Canadian (ironware)/Dutch (electronics and software) construction.
by mediavets » Fri Aug 16, 2013 10:08 pm
pranshu14 wrote:First is after cropping 18 GP but second is without crop 13GP
Were both rendered at 100% ?
Artisan New
by Artisan New » Sat Aug 17, 2013 7:50 am
Indeed Adrew, that's what I thought as well. Using occams razor it's the only probable explanation.
Greets, Ed.
pranshu14
by pranshu14 » Sat Aug 17, 2013 4:59 pm
Yes both were rendered at 100%
shooting pattern was
row wise left to right downward with 25% overlapping.
The image preview is also same in both the cases but not the resolution.
by mediavets » Sat Aug 17, 2013 8:15 pm
So.. did you shoot this pano with a Gigapan robotic head?
If so, did you use the APG Gigapan Import Wizard?
lumelix
by lumelix » Sat Aug 17, 2013 8:33 pm
Hi
Small differences between two separate pano-detections from the same input files are normal.
But this one is a little bit hefty!
Have a look into the layer list at the bottom of the editor and check there the values for the calculated image focal length.
There you will see the difference that happens depending from the EXIF information that were avaible in the input files.
LR can delete some EXIFs that where needed by APG.
Regards
Martin
pranshu14
by pranshu14 » Sun Aug 18, 2013 7:37 am
Focal length is same in both the cases which is there in APG.
lumelix wrote:Hi
pranshu14
by pranshu14 » Sun Aug 18, 2013 7:38 am
yes i used gigapan and then gigapan import wizard.
mediavets wrote:
pranshu14 wrote:
mediavets wrote:Were both rendered at 100% ?
lumelix
by lumelix » Sun Aug 18, 2013 12:44 pm
pranshu14 wrote:Focal length is same in both the cases which is there in APG.
Show us two screenshots of the first images down in the layer list, so we can see all the values.
Regards
Martin
