Having trouble importing pappywizard xml files from Panoshoot
vaccinemedia
by vaccinemedia » Sat Jul 20, 2013 11:54 am
I have the panoshoot wifi module for the panogear motorised head. It says it saves xml files compatible with autopano but I'm struggling ti import them. I am going to import and selecting papywizard and selecting the xml file downloaded from panoshoot for the session and it's not picking up any images and the pitch and yaw have off values. See image
Here is the generated xml file:
<?xml version="1.0" encoding="utf-8" ?>
<panoshoot xml_revision="1.1">
<session num="1">
    <header>
        <sessionInfo>
            <title>null</title>
            <Author>null</Author>
            <Comments>null</Comments>
            <totalPictures>70</totalPictures>
            <totalPicpoints>70</totalPicpoints>
            <startTime>2013-07-19T21:31:10.1</startTime>
            <endTime>2013-07-19T21:43:51.0</endTime>
            <yawSweep min="-174.00" max=" 173.98" sweep="-12.01"/>
            <pitchSweep min="-79.88" max=" 81.31" sweep=" 161.19"/>
            <location/>
        </sessionInfo>
        <profile option="1" id="4">
            <name>Canon 60D 18mm</name>
            <cameraInfo>
                <calculated_fieldOfView horizontal="45.24" vertical="64.01"/>
                <cameraOrientation>portrait-left</cameraOrientation>
                <lens type="rectilinear" focal="18" opticalMulti="1"/>
                <sensor ratio="3:2" coef="1.60" resolution="18"/>
            </cameraInfo>
            <timing>
                <stabilizationPause>1</stabilizationPause>
                <obturatorTime>4</obturatorTime>
                <afterShootPause>0</afterShootPause>
            </timing>
            <limits>
                <yaw min="-180" max="180"/>
                <pitch min="-90" max="90"/>
            </limits>
        </profile>
        <runner type="mosaic">
            <name>mosaic 360x180 18mm</name>
            <nbPicts horizontal="14" vertical="5"/>
            <Overlap minimum="25"/>
        </runner>
        <head_handlers>
            <MC_driver version="2.12.132"/>
            <panoshoot_driver build="99">
                <name>panogear adaptative learning</name>
                <fuzzy_params subject_distance="3" units="meters" inertia="standard"/>
            </panoshoot_driver>
        </head_handlers>
    </header>
    <shoot>
    <pict id="1" bracket="1">
        <time>2013-07-19T21:31:10.1</time>
        <position yaw="-173.986" pitch=" 81.318" roll="0"/>
    </pict>
    <pict id="2" bracket="1">
        <time>2013-07-19T21:31:20.6</time>
        <position yaw="-150.262" pitch=" 81.318" roll="0"/>
    </pict>
    <pict id="3" bracket="1">
        <time>2013-07-19T21:31:31.5</time>
        <position yaw="-123.220" pitch=" 81.318" roll="0"/>
    </pict>
    <pict id="4" bracket="1">
        <time>2013-07-19T21:31:42.5</time>
        <position yaw="-96.221" pitch=" 81.318" roll="0"/>
    </pict>
    <pict id="5" bracket="1">
        <time>2013-07-19T21:31:53.5</time>
        <position yaw="-69.186" pitch=" 81.318" roll="0"/>
    </pict>
    <pict id="6" bracket="1">
        <time>2013-07-19T21:32:04.4</time>
        <position yaw="-42.206" pitch=" 81.318" roll="0"/>
    </pict>
    <pict id="7" bracket="1">
        <time>2013-07-19T21:32:15.4</time>
        <position yaw="-15.144" pitch=" 81.318" roll="0"/>
    </pict>
    <pict id="8" bracket="1">
        <time>2013-07-19T21:32:26.3</time>
        <position yaw=" 11.794" pitch=" 81.318" roll="0"/>
    </pict>
    <pict id="9" bracket="1">
        <time>2013-07-19T21:32:37.3</time>
        <position yaw=" 38.885" pitch=" 81.318" roll="0"/>
    </pict>
    <pict id="10" bracket="1">
        <time>2013-07-19T21:32:48.3</time>
        <position yaw=" 65.876" pitch=" 81.318" roll="0"/>
    </pict>
    <pict id="11" bracket="1">
        <time>2013-07-19T21:32:59.2</time>
        <position yaw=" 92.920" pitch=" 81.318" roll="0"/>
    </pict>
    <pict id="12" bracket="1">
        <time>2013-07-19T21:33:10.2</time>
        <position yaw=" 119.943" pitch=" 81.318" roll="0"/>
    </pict>
    <pict id="13" bracket="1">
        <time>2013-07-19T21:33:21.1</time>
        <position yaw=" 146.953" pitch=" 81.318" roll="0"/>
    </pict>
    <pict id="14" bracket="1">
        <time>2013-07-19T21:33:32.1</time>
        <position yaw=" 173.964" pitch=" 81.318" roll="0"/>
    </pict>
    <pict id="15" bracket="1">
        <time>2013-07-19T21:33:44.9</time>
        <position yaw=" 173.964" pitch=" 42.080" roll="0"/>
    </pict>
    <pict id="16" bracket="1">
        <time>2013-07-19T21:33:55.3</time>
        <position yaw=" 150.196" pitch=" 42.080" roll="0"/>
    </pict>
    <pict id="17" bracket="1">
        <time>2013-07-19T21:34:06.3</time>
        <position yaw=" 123.167" pitch=" 42.080" roll="0"/>
    </pict>
    <pict id="18" bracket="1">
        <time>2013-07-19T21:34:17.2</time>
        <position yaw=" 96.156" pitch=" 42.080" roll="0"/>
    </pict>
    <pict id="19" bracket="1">
        <time>2013-07-19T21:34:28.2</time>
        <position yaw=" 69.152" pitch=" 42.080" roll="0"/>
    </pict>
    <pict id="20" bracket="1">
        <time>2013-07-19T21:34:39.2</time>
        <position yaw=" 42.134" pitch=" 42.080" roll="0"/>
    </pict>
    <pict id="21" bracket="1">
        <time>2013-07-19T21:34:50.1</time>
        <position yaw=" 15.175" pitch=" 42.080" roll="0"/>
    </pict>
    <pict id="22" bracket="1">
        <time>2013-07-19T21:35:01.1</time>
        <position yaw="-11.881" pitch=" 42.080" roll="0"/>
    </pict>
    <pict id="23" bracket="1">
        <time>2013-07-19T21:35:12.0</time>
        <position yaw="-38.871" pitch=" 42.080" roll="0"/>
    </pict>
    <pict id="24" bracket="1">
        <time>2013-07-19T21:35:23.0</time>
        <position yaw="-65.912" pitch=" 42.080" roll="0"/>
    </pict>
    <pict id="25" bracket="1">
        <time>2013-07-19T21:35:34.0</time>
        <position yaw="-92.938" pitch=" 42.080" roll="0"/>
    </pict>
    <pict id="26" bracket="1">
        <time>2013-07-19T21:35:44.9</time>
        <position yaw="-119.945" pitch=" 42.080" roll="0"/>
    </pict>
    <pict id="27" bracket="1">
        <time>2013-07-19T21:35:55.9</time>
        <position yaw="-146.979" pitch=" 42.080" roll="0"/>
    </pict>
    <pict id="28" bracket="1">
        <time>2013-07-19T21:36:06.8</time>
        <position yaw="-174.007" pitch=" 42.080" roll="0"/>
    </pict>
    <pict id="29" bracket="1">
        <time>2013-07-19T21:36:19.6</time>
        <position yaw="-174.007" pitch=" 1.248" roll="0"/>
    </pict>
    <pict id="30" bracket="1">
        <time>2013-07-19T21:36:30.1</time>
        <position yaw="-150.249" pitch=" 1.248" roll="0"/>
    </pict>
    <pict id="31" bracket="1">
        <time>2013-07-19T21:36:41.0</time>
        <position yaw="-123.212" pitch=" 1.248" roll="0"/>
    </pict>
    <pict id="32" bracket="1">
        <time>2013-07-19T21:36:52.0</time>
        <position yaw="-96.213" pitch=" 1.248" roll="0"/>
    </pict>
    <pict id="33" bracket="1">
        <time>2013-07-19T21:37:02.9</time>
        <position yaw="-69.178" pitch=" 1.248" roll="0"/>
    </pict>
    <pict id="34" bracket="1">
        <time>2013-07-19T21:37:13.9</time>
        <position yaw="-42.180" pitch=" 1.248" roll="0"/>
    </pict>
    <pict id="35" bracket="1">
        <time>2013-07-19T21:37:24.9</time>
        <position yaw="-15.147" pitch=" 1.248" roll="0"/>
    </pict>
    <pict id="36" bracket="1">
        <time>2013-07-19T21:37:35.8</time>
        <position yaw=" 11.795" pitch=" 1.248" roll="0"/>
    </pict>
    <pict id="37" bracket="1">
        <time>2013-07-19T21:37:46.8</time>
        <position yaw=" 38.887" pitch=" 1.248" roll="0"/>
    </pict>
    <pict id="38" bracket="1">
        <time>2013-07-19T21:37:57.7</time>
        <position yaw=" 65.887" pitch=" 1.248" roll="0"/>
    </pict>
    <pict id="39" bracket="1">
        <time>2013-07-19T21:38:08.7</time>
        <position yaw=" 92.916" pitch=" 1.248" roll="0"/>
    </pict>
    <pict id="40" bracket="1">
        <time>2013-07-19T21:38:19.6</time>
        <position yaw=" 119.947" pitch=" 1.248" roll="0"/>
    </pict>
    <pict id="41" bracket="1">
        <time>2013-07-19T21:38:30.6</time>
        <position yaw=" 146.952" pitch=" 1.248" roll="0"/>
    </pict>
    <pict id="42" bracket="1">
        <time>2013-07-19T21:38:41.6</time>
        <position yaw=" 173.973" pitch=" 1.248" roll="0"/>
    </pict>
    <pict id="43" bracket="1">
        <time>2013-07-19T21:38:54.4</time>
        <position yaw=" 173.973" pitch="-39.365" roll="0"/>
    </pict>
    <pict id="44" bracket="1">
        <time>2013-07-19T21:39:04.8</time>
        <position yaw=" 150.191" pitch="-39.365" roll="0"/>
    </pict>
    <pict id="45" bracket="1">
        <time>2013-07-19T21:39:15.8</time>
        <position yaw=" 123.180" pitch="-39.365" roll="0"/>
    </pict>
    <pict id="46" bracket="1">
        <time>2013-07-19T21:39:26.7</time>
        <position yaw=" 96.144" pitch="-39.365" roll="0"/>
    </pict>
    <pict id="47" bracket="1">
        <time>2013-07-19T21:39:37.7</time>
        <position yaw=" 69.155" pitch="-39.365" roll="0"/>
    </pict>
    <pict id="48" bracket="1">
        <time>2013-07-19T21:39:48.6</time>
        <position yaw=" 42.141" pitch="-39.365" roll="0"/>
    </pict>
    <pict id="49" bracket="1">
        <time>2013-07-19T21:39:59.6</time>
        <position yaw=" 15.183" pitch="-39.365" roll="0"/>
    </pict>
    <pict id="50" bracket="1">
        <time>2013-07-19T21:40:10.5</time>
        <position yaw="-11.883" pitch="-39.365" roll="0"/>
    </pict>
    <pict id="51" bracket="1">
        <time>2013-07-19T21:40:21.5</time>
        <position yaw="-38.883" pitch="-39.365" roll="0"/>
    </pict>
    <pict id="52" bracket="1">
        <time>2013-07-19T21:40:32.5</time>
        <position yaw="-65.929" pitch="-39.365" roll="0"/>
    </pict>
    <pict id="53" bracket="1">
        <time>2013-07-19T21:40:43.4</time>
        <position yaw="-92.941" pitch="-39.365" roll="0"/>
    </pict>
    <pict id="54" bracket="1">
        <time>2013-07-19T21:40:54.4</time>
        <position yaw="-119.932" pitch="-39.365" roll="0"/>
    </pict>
    <pict id="55" bracket="1">
        <time>2013-07-19T21:41:05.3</time>
        <position yaw="-146.962" pitch="-39.365" roll="0"/>
    </pict>
    <pict id="56" bracket="1">
        <time>2013-07-19T21:41:16.3</time>
        <position yaw="-173.983" pitch="-39.365" roll="0"/>
    </pict>
    <pict id="57" bracket="1">
        <time>2013-07-19T21:41:29.1</time>
        <position yaw="-173.983" pitch="-79.880" roll="0"/>
    </pict>
    <pict id="58" bracket="1">
        <time>2013-07-19T21:41:39.5</time>
        <position yaw="-150.252" pitch="-79.880" roll="0"/>
    </pict>
    <pict id="59" bracket="1">
        <time>2013-07-19T21:41:50.5</time>
        <position yaw="-123.210" pitch="-79.880" roll="0"/>
    </pict>
    <pict id="60" bracket="1">
        <time>2013-07-19T21:42:01.4</time>
        <position yaw="-96.211" pitch="-79.880" roll="0"/>
    </pict>
    <pict id="61" bracket="1">
        <time>2013-07-19T21:42:12.4</time>
        <position yaw="-69.184" pitch="-79.880" roll="0"/>
    </pict>
    <pict id="62" bracket="1">
        <time>2013-07-19T21:42:23.4</time>
        <position yaw="-42.194" pitch="-79.880" roll="0"/>
    </pict>
    <pict id="63" bracket="1">
        <time>2013-07-19T21:42:34.3</time>
        <position yaw="-15.144" pitch="-79.880" roll="0"/>
    </pict>
    <pict id="64" bracket="1">
        <time>2013-07-19T21:42:45.3</time>
        <position yaw=" 11.795" pitch="-79.880" roll="0"/>
    </pict>
    <pict id="65" bracket="1">
        <time>2013-07-19T21:42:56.2</time>
        <position yaw=" 38.895" pitch="-79.880" roll="0"/>
    </pict>
    <pict id="66" bracket="1">
        <time>2013-07-19T21:43:07.2</time>
        <position yaw=" 65.885" pitch="-79.880" roll="0"/>
    </pict>
    <pict id="67" bracket="1">
        <time>2013-07-19T21:43:18.2</time>
        <position yaw=" 92.928" pitch="-79.880" roll="0"/>
    </pict>
    <pict id="68" bracket="1">
        <time>2013-07-19T21:43:29.1</time>
        <position yaw=" 119.948" pitch="-79.880" roll="0"/>
    </pict>
    <pict id="69" bracket="1">
        <time>2013-07-19T21:43:40.1</time>
        <position yaw=" 146.967" pitch="-79.880" roll="0"/>
    </pict>
    <pict id="70" bracket="1">
        <time>2013-07-19T21:43:51.0</time>
        <position yaw=" 173.980" pitch="-79.880" roll="0"/>
    </pict>
    </shoot>
</session>
</panoshoot>
by mediavets » Sat Jul 20, 2013 12:52 pm
vaccinemedia wrote:I have the panoshoot wifi module for the panogear motorised head. It says it saves xml files compatible with autopano but I'm struggling ti import them. I am going to import and selecting papywizard and selecting the xml file downloaded from panoshoot for the session and it's not picking up any images and the pitch and yaw have off values. See image
You have to tell APP/APG where to find the images and select those relevant to the XML - they are not found automatically. There's no explicit link betwen the XML file and the images.
Not quite sure what you mean by 'off values'. Although it's rather absurd for Panoshoot to record yaw and pitch values to three decimal places.
vaccinemedia
by vaccinemedia » Sat Jul 20, 2013 2:00 pm
By off values I mean the 3.40282e+38 value which the wizard has for yaw and pitch when selecting the xml file. When further selecting the images they are listed but now loaded into the preview window and the finish button is disabled (see extra uploaded images) so I can't continue
vaccinemedia
by vaccinemedia » Sat Jul 20, 2013 5:11 pm
Managed to get it sorted :D Panoshoot was creating multisession xml files. When I disabled this option the xml files could be read and used and I'm currently rendering the first test.
by mediavets » Sat Jul 20, 2013 7:22 pm
vaccinemedia wrote:Managed to get it sorted :D Panoshoot was creating multisession xml files. When I disabled this option the xml files could be read and used and I'm currently rendering the first test.
OK - I don't think that anyone from Panoshoit has ever explained what possible use multi-session XML files are.
