G Sensor of IOS
flowmotion
G Sensor of IOS
by flowmotion » Mon Jul 08, 2013 4:26 pm
Hey guys, i found a panorama player, that uses the g sensor of the ipad for screening, which is really funny. You move around and the pano does also. (here teh link http://www.sitte-wohnen.de/360/)
can you tell me, how this is done? Is that possible with our kolor software also?
by klausesser » Mon Jul 08, 2013 4:34 pm
flowmotion wrote:Hey guys, i found a panorama player, that uses the g sensor of the ipad for screening, which is really funny. You move around and the pano does also. (here teh link http://www.sitte-wohnen.de/360/)
In PTP 1.8 just activate "Gyroscope" in "project properties" >> "extras" >> "enable" and you´re done!
flowmotion
by flowmotion » Mon Jul 08, 2013 5:27 pm
OKAY - THAT sounds really easy :)
THX
by klausesser » Mon Jul 08, 2013 8:01 pm
flowmotion wrote:OKAY - THAT sounds really easy :)
THX
It is! :cool:
BUT: little planet-intro doesn´t work on iPads.
flowmotion
by flowmotion » Tue Jul 09, 2013 8:40 am
Hey, me again. i can´t find. I´ll write in german my way:
PTP 1.8.0.
Fenster rechts: Projekteigenschaften - Da hab ich die Reiter
Darstellung
Verhalten
Sonstige
Tour erstellen...
Aber nichts mit Gyroskop
Und noch ne Blà¶de Frage:
Kann man die Panorama Grà¶àŸe (Kantenlà¤ngen) direkt in PTP bestimmen? Meine Tour hat aktuell um die 700MB - bissl viel fürs Inet :D
by mediavets » Tue Jul 09, 2013 9:37 am
flowmotion wrote:Hey, me again. i can´t find. I´ll write in german my way:
PTP 1.8.0.
Darstellung
Verhalten
Sonstige
Tour erstellen...
:D
You are looking in the wrong place:
flowmotion
by flowmotion » Tue Jul 09, 2013 9:39 am
GEFUNDEN!!!! DANKE
by mediavets » Tue Jul 09, 2013 9:42 am
flowmotion wrote:Und noch ne Blà¶de Frage:
If I understand your question correctly, that's not an issue really. PTP/krpano supports multi resolution tiling which copes with pano images of any size without significant impact on the viewing platform performance.
The current verson of PTP (v. 1.8) does not support multi-res. on iDevices but instead delivers a reduced size set of cube faces when tour is viewed with an iDevice.
flowmotion
by flowmotion » Tue Jul 09, 2013 9:44 am
hi there ...
sorry, i wrote in german.
my issue is, that the project files of the tour are quite large. Around 700 MB
so for using it really fluent in the Web it might be a good idea to use smaller panoramas (instead of 25000 pixels may be 12000 width) and a lower jpg quality.
I think i can remember, that in earliere versions i could specify the max size of a panorama. But iforogot how to do that :D
by klausesser » Tue Jul 09, 2013 2:33 pm
flowmotion wrote:hi there ...
Use jpg=7 or max. 8. That´s quite sufficient. But use RAW-->>TIFFs during the stitch- and rendering procedure - this way you have good quality when the jpg-compressions
starts.
Never use jpg for stitching/rendering when you want to maintain good image-quality.
I just loaded up an indoor-tour of an art-exhibition which has 20 nodes resulting in 900MB on the server . . . that´s the price you pay for hires . . . :cool:
by klausesser » Wed Jul 10, 2013 12:48 pm
flowmotion wrote:I think i can remember, that in earliere versions i could specify the max size of a panorama. But iforogot how to do that :D
In terms of data-amount preferably specify the final render-size in the stitcher by setting the size of the equirectangular image.
In PTP you can use the compression to minimize the tour-size. But NEVER use less than 7 - you risk posterizing in delicate color-ranges.
I usually use 7. My 700mpx tours with average 12 scenes result in about 180-200MB on the server.
PS: again - don´t use jpg in the stitch- and render process. Import TIF to PTP - the compression of the tiles which takes place then in PTP
works better basing on TIFs.
PS2:
Even very big data can work fluently via the web - that´s because of multiresolution.
See heer a mixed 700Mpx/3,5Gpx: http://www.360impressions.de/WandelHalle/
The data on the server is about 400MB
flowmotion
Re: G Sensor of IOS
by flowmotion » Tue Jan 21, 2014 3:59 pm
hey guys, me again - sitting on another tour.
Is there a hack, how to use a map and also the gyroscope sensor?
Re: G Sensor of IOS
by mediavets » Tue Jan 21, 2014 6:21 pm
flowmotion wrote:hey guys, me again - sitting on another tour.
I think your question relates to Panotour or Panotour pro yet you have posted in the Autopano Pro/Giga section of the forum.
flowmotion
Re: G Sensor of IOS
by flowmotion » Wed Jan 22, 2014 10:22 am
oh sorry- can anyone move that thread
