How to improve stitching ? RMS under 3.0
Baldev
by Baldev » Thu Jun 27, 2013 11:17 pm
HI
How can I improve spots like this ( screenshot ) ? The RMS is under 3.0
http://img811.imageshack.us/img811/1485/qll3.jpg
I worked with the 3 lense distortion Renderings. And improved all the control points manual.
So this spots like on the screenshot. What can I do about it? With Masks I can sometimes get better results.
So can this be because I shot the pictures without Nodalpoint-finder? What other reasons can this have?
Thanks!!
I
by mediavets » Thu Jun 27, 2013 11:31 pm
Baldev wrote:So can this be because I shot the pictures without Nodalpoint-finder?
Yes.
What lens and camera did you use?
Baldev
by Baldev » Fri Jun 28, 2013 5:46 pm
Hi
Panasonic Lumix DMC - FZ150 the lense is 25mm Wide. Of course All settings Manual. Iso, Whitebalance, Focus,( is Focus actually necessary to make it manual? ) and exposure.
So are there any possibilities to get a better result without a nodalpointfinder? I just use a Tripod.
Baldi
by mediavets » Fri Jun 28, 2013 6:23 pm
Baldev wrote:Hi
Baldi
No - I don't think so.
You might be able to 'get away' with it if shooting a partial pano (less than 360 x 180 dgeress Feild of View) of an outdoor scene with nothing close to the camera but not indoors.
by klausesser » Fri Jun 28, 2013 6:28 pm
Baldev wrote:Hi
Baldi
You need to FIND the "Nodalpoint" - in fact the entrance-pupil aka NoParallaxPoint - but you need a "Nodal-Adapter" aka "panorama-head" to shoot a panorama.
This head allows you to pan and tilt the camera-/lens-combination around the NPP for avoiding any parallaxe.
To begin with i suggest a NodalNinja.
Parallaxe causes stitch-errors.
So: yes - you´ll get the best results with a) exactly *finding* the NPP and b) precisely *aligning* your camera/lens according to your findings.
mosleyhgp
by mosleyhgp » Fri Jun 28, 2013 7:01 pm
And remember (since the FZ-150 is a superzoom) that the Nodal point is different at different focal lengths.
Baldev
by Baldev » Fri Jun 28, 2013 10:22 pm
Hi
Ok I thougt that this answer will come :D It doesn´t help me for the moment but Thanks anyway.
Im very amazed how much good feedback I get here. Very nice forum! THX!
HansKeesom
by HansKeesom » Fri Jun 28, 2013 10:59 pm
Making sure your nodal point is perfect is the best things to do.
Still, these things can often be repaired in APG with markers. It is matter of finding the picture in which the whole line that is broken is present and use green markers on it. When there is not one picture that holds the whole line it still can be done but it still can be done.
Regards, Hans Keesom
