Looking for a Clauss XML
con
by con » Tue Jun 18, 2013 11:25 am
Just doing some playing around and wanted to see if i could get my hands on a Clauss Head xml or whatever data is spits out at the end.
Iw ant to have a play with the plugin and see what i can do with it.
anyone have one I can use - preferably with less than 100 images, or even smaller - thanks!
shayke
Re: Looking for a Clauss XML
by shayke » Mon Feb 10, 2014 4:18 pm
Hi con,
I am looking for the same thing. did you managet to get one?
Shay
by klausesser » Mon Feb 10, 2014 5:05 pm
con wrote:Just doing some playing around and wanted to see if i could get my hands on a Clauss Head xml or whatever data is spits out at the end.
Only makes sense if you use a Dr. Clauss Rodeon for shooting, of course.
I suggest trying the more common PapyWizard-XML.
PS: i can post a PapyWizard-XML the Panoneed head writes: http://panoneed.com
by klausesser » Mon Feb 10, 2014 5:23 pm
Con, Shay - here is a XML file the Panoneed head writes. I guess the Dr. Clauss XML is very familiar, but of course not the same.
Just as an example.
Lens: 85mm
Sensor: FX
200 shots
Full sphere without Nadir.
Result:
http://www.klausesser.de/Stadthalle
http://www.360impressions.de/Medienhafen
<?xml version="1.0" encoding="utf-8"?>
<papywizard version="c">
    <header>
        <general>
            <title>
             Start 19:53:43 21.07.2013  End 20:05:47 21.07.2013
            </title>
            <gps>
            </gps>
            <comment>
                Generated by PANONEED
            </comment>
        </general>
        <shooting mode="preset">
            <headOrientation>
                up
            </headOrientation>
            <cameraOrientation>
               portrait
            </cameraOrientation>
            <stabilizationDelay>
                0.5
            </stabilizationDelay>
            <startTime>
              19:53:43 21.07.2013
            </startTime>
            <endTime>
              20:05:47 21.07.2013
            </endTime>
        </shooting>
        <camera>
            <timeValue>
                1.0
            </timeValue>
            <bracketing nbPicts="001"/>
            <sensor coef="1.0" ratio="3:2 "/>
       </camera>
        <lens type="rectilinear">
            <focal>
                85.0
            </focal>
        </lens>
        <preset name="              "/>
    </header>
    <shoot>
        <pict bracket="001" id="0001">
            <time>
            </time>
            <position pitch="-074.0" yaw="+000.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0002">
            <time>
            </time>
            <position pitch="-074.0" yaw="+030.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0003">
            <time>
            </time>
            <position pitch="-074.0" yaw="+060.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0004">
            <time>
            </time>
            <position pitch="-074.0" yaw="+089.9" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0005">
            <time>
            </time>
            <position pitch="-074.0" yaw="+120.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0006">
            <time>
            </time>
            <position pitch="-074.0" yaw="+150.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0007">
            <time>
            </time>
            <position pitch="-074.0" yaw="+180.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0008">
            <time>
            </time>
            <position pitch="-074.0" yaw="+210.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0009">
            <time>
            </time>
            <position pitch="-074.0" yaw="+240.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0010">
            <time>
            </time>
            <position pitch="-074.0" yaw="+270.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0011">
            <time>
            </time>
            <position pitch="-074.0" yaw="+300.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0012">
            <time>
            </time>
            <position pitch="-074.0" yaw="+330.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0013">
            <time>
            </time>
            <position pitch="-055.5" yaw="+342.1" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0014">
            <time>
            </time>
            <position pitch="-055.5" yaw="+324.1" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0015">
            <time>
            </time>
            <position pitch="-055.5" yaw="+306.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0016">
            <time>
            </time>
            <position pitch="-055.5" yaw="+288.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0017">
            <time>
            </time>
            <position pitch="-055.5" yaw="+270.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0018">
            <time>
            </time>
            <position pitch="-055.5" yaw="+252.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0019">
            <time>
            </time>
            <position pitch="-055.5" yaw="+234.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0020">
            <time>
            </time>
            <position pitch="-055.5" yaw="+216.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0021">
            <time>
            </time>
            <position pitch="-055.5" yaw="+198.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0022">
            <time>
            </time>
            <position pitch="-055.5" yaw="+180.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0023">
            <time>
            </time>
            <position pitch="-055.5" yaw="+162.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0024">
            <time>
            </time>
            <position pitch="-055.5" yaw="+144.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0025">
            <time>
            </time>
            <position pitch="-055.5" yaw="+126.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0026">
            <time>
            </time>
            <position pitch="-055.5" yaw="+108.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0027">
            <time>
            </time>
            <position pitch="-055.5" yaw="+090.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0028">
            <time>
            </time>
            <position pitch="-055.5" yaw="+072.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0029">
            <time>
            </time>
            <position pitch="-055.5" yaw="+054.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0030">
            <time>
            </time>
            <position pitch="-055.5" yaw="+036.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0031">
            <time>
            </time>
            <position pitch="-055.5" yaw="+018.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0032">
            <time>
            </time>
            <position pitch="-055.5" yaw="+000.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0033">
            <time>
            </time>
            <position pitch="-037.0" yaw="+000.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0034">
            <time>
            </time>
            <position pitch="-037.0" yaw="+014.4" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0035">
            <time>
            </time>
            <position pitch="-037.0" yaw="+028.8" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0036">
            <time>
            </time>
            <position pitch="-037.0" yaw="+043.2" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0037">
            <time>
            </time>
            <position pitch="-037.0" yaw="+057.6" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0038">
            <time>
            </time>
            <position pitch="-037.0" yaw="+072.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0039">
            <time>
            </time>
            <position pitch="-037.0" yaw="+086.4" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0040">
            <time>
            </time>
            <position pitch="-037.0" yaw="+100.8" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0041">
            <time>
            </time>
            <position pitch="-037.0" yaw="+115.2" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0042">
            <time>
            </time>
            <position pitch="-037.0" yaw="+129.6" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0043">
            <time>
            </time>
            <position pitch="-037.0" yaw="+144.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0044">
            <time>
            </time>
            <position pitch="-037.0" yaw="+158.4" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0045">
            <time>
            </time>
            <position pitch="-037.0" yaw="+172.8" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0046">
            <time>
            </time>
            <position pitch="-037.0" yaw="+187.2" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0047">
            <time>
            </time>
            <position pitch="-037.0" yaw="+201.6" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0048">
            <time>
            </time>
            <position pitch="-037.0" yaw="+216.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0049">
            <time>
            </time>
            <position pitch="-037.0" yaw="+230.4" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0050">
            <time>
            </time>
            <position pitch="-037.0" yaw="+244.8" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0051">
            <time>
            </time>
            <position pitch="-037.0" yaw="+259.2" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0052">
            <time>
            </time>
            <position pitch="-037.0" yaw="+273.6" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0053">
            <time>
            </time>
            <position pitch="-037.0" yaw="+288.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0054">
            <time>
            </time>
            <position pitch="-037.0" yaw="+302.4" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0055">
            <time>
            </time>
            <position pitch="-037.0" yaw="+316.8" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0056">
            <time>
            </time>
            <position pitch="-037.0" yaw="+331.3" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0057">
            <time>
            </time>
            <position pitch="-037.0" yaw="+345.7" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0058">
            <time>
            </time>
            <position pitch="-018.4" yaw="+347.2" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0059">
            <time>
            </time>
            <position pitch="-018.4" yaw="+334.3" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0060">
            <time>
            </time>
            <position pitch="-018.4" yaw="+321.5" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0061">
            <time>
            </time>
            <position pitch="-018.4" yaw="+308.6" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0062">
            <time>
            </time>
            <position pitch="-018.4" yaw="+295.7" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0063">
            <time>
            </time>
            <position pitch="-018.4" yaw="+282.9" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0064">
            <time>
            </time>
            <position pitch="-018.4" yaw="+270.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0065">
            <time>
            </time>
            <position pitch="-018.4" yaw="+257.1" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0066">
            <time>
            </time>
            <position pitch="-018.4" yaw="+244.3" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0067">
            <time>
            </time>
            <position pitch="-018.4" yaw="+231.4" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0068">
            <time>
            </time>
            <position pitch="-018.4" yaw="+218.6" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0069">
            <time>
            </time>
            <position pitch="-018.4" yaw="+205.7" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0070">
            <time>
            </time>
            <position pitch="-018.4" yaw="+192.9" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0071">
            <time>
            </time>
            <position pitch="-018.4" yaw="+180.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0072">
            <time>
            </time>
            <position pitch="-018.4" yaw="+167.1" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0073">
            <time>
            </time>
            <position pitch="-018.4" yaw="+154.3" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0074">
            <time>
            </time>
            <position pitch="-018.4" yaw="+141.4" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0075">
            <time>
            </time>
            <position pitch="-018.4" yaw="+128.6" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0076">
            <time>
            </time>
            <position pitch="-018.4" yaw="+115.7" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0077">
            <time>
            </time>
            <position pitch="-018.4" yaw="+102.8" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0078">
            <time>
            </time>
            <position pitch="-018.4" yaw="+089.9" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0079">
            <time>
            </time>
            <position pitch="-018.4" yaw="+077.1" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0080">
            <time>
            </time>
            <position pitch="-018.4" yaw="+064.2" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0081">
            <time>
            </time>
            <position pitch="-018.4" yaw="+051.4" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0082">
            <time>
            </time>
            <position pitch="-018.4" yaw="+038.5" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0083">
            <time>
            </time>
            <position pitch="-018.4" yaw="+025.7" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0084">
            <time>
            </time>
            <position pitch="-018.4" yaw="+012.8" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0085">
            <time>
            </time>
            <position pitch="-018.4" yaw="+000.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0086">
            <time>
            </time>
            <position pitch="+000.0" yaw="+000.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0087">
            <time>
            </time>
            <position pitch="+000.0" yaw="+012.3" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0088">
            <time>
            </time>
            <position pitch="+000.0" yaw="+024.8" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0089">
            <time>
            </time>
            <position pitch="+000.0" yaw="+037.2" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0090">
            <time>
            </time>
            <position pitch="+000.0" yaw="+049.6" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0091">
            <time>
            </time>
            <position pitch="+000.0" yaw="+062.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0092">
            <time>
            </time>
            <position pitch="+000.0" yaw="+074.4" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0093">
            <time>
            </time>
            <position pitch="+000.0" yaw="+086.9" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0094">
            <time>
            </time>
            <position pitch="+000.0" yaw="+099.3" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0095">
            <time>
            </time>
            <position pitch="+000.0" yaw="+111.7" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0096">
            <time>
            </time>
            <position pitch="+000.0" yaw="+124.1" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0097">
            <time>
            </time>
            <position pitch="+000.0" yaw="+136.5" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0098">
            <time>
            </time>
            <position pitch="+000.0" yaw="+148.9" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0099">
            <time>
            </time>
            <position pitch="+000.0" yaw="+161.4" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0100">
            <time>
            </time>
            <position pitch="+000.0" yaw="+173.8" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0101">
            <time>
            </time>
            <position pitch="+000.0" yaw="+186.2" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0102">
            <time>
            </time>
            <position pitch="+000.0" yaw="+198.6" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0103">
            <time>
            </time>
            <position pitch="+000.0" yaw="+211.1" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0104">
            <time>
            </time>
            <position pitch="+000.0" yaw="+223.4" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0105">
            <time>
            </time>
            <position pitch="+000.0" yaw="+235.9" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0106">
            <time>
            </time>
            <position pitch="+000.0" yaw="+248.3" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0107">
            <time>
            </time>
            <position pitch="+000.0" yaw="+260.7" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0108">
            <time>
            </time>
            <position pitch="+000.0" yaw="+273.1" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0109">
            <time>
            </time>
            <position pitch="+000.0" yaw="+285.6" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0110">
            <time>
            </time>
            <position pitch="+000.0" yaw="+297.9" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0111">
            <time>
            </time>
            <position pitch="+000.0" yaw="+310.4" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0112">
            <time>
            </time>
            <position pitch="+000.0" yaw="+322.8" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0113">
            <time>
            </time>
            <position pitch="+000.0" yaw="+335.2" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0114">
            <time>
            </time>
            <position pitch="+000.0" yaw="+347.6" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0115">
            <time>
            </time>
            <position pitch="+018.5" yaw="+347.2" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0116">
            <time>
            </time>
            <position pitch="+018.5" yaw="+334.3" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0117">
            <time>
            </time>
            <position pitch="+018.5" yaw="+321.5" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0118">
            <time>
            </time>
            <position pitch="+018.5" yaw="+308.6" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0119">
            <time>
            </time>
            <position pitch="+018.5" yaw="+295.7" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0120">
            <time>
            </time>
            <position pitch="+018.5" yaw="+282.9" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0121">
            <time>
            </time>
            <position pitch="+018.5" yaw="+270.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0122">
            <time>
            </time>
            <position pitch="+018.5" yaw="+257.1" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0123">
            <time>
            </time>
            <position pitch="+018.5" yaw="+244.3" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0124">
            <time>
            </time>
            <position pitch="+018.5" yaw="+231.4" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0125">
            <time>
            </time>
            <position pitch="+018.5" yaw="+218.6" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0126">
            <time>
            </time>
            <position pitch="+018.5" yaw="+205.7" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0127">
            <time>
            </time>
            <position pitch="+018.5" yaw="+192.9" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0128">
            <time>
            </time>
            <position pitch="+018.5" yaw="+180.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0129">
            <time>
            </time>
            <position pitch="+018.5" yaw="+167.1" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0130">
            <time>
            </time>
            <position pitch="+018.5" yaw="+154.3" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0131">
            <time>
            </time>
            <position pitch="+018.5" yaw="+141.4" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0132">
            <time>
            </time>
            <position pitch="+018.5" yaw="+128.6" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0133">
            <time>
            </time>
            <position pitch="+018.5" yaw="+115.7" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0134">
            <time>
            </time>
            <position pitch="+018.5" yaw="+102.8" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0135">
            <time>
            </time>
            <position pitch="+018.5" yaw="+089.9" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0136">
            <time>
            </time>
            <position pitch="+018.5" yaw="+077.1" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0137">
            <time>
            </time>
            <position pitch="+018.5" yaw="+064.2" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0138">
            <time>
            </time>
            <position pitch="+018.5" yaw="+051.4" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0139">
            <time>
            </time>
            <position pitch="+018.5" yaw="+038.5" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0140">
            <time>
            </time>
            <position pitch="+018.5" yaw="+025.7" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0141">
            <time>
            </time>
            <position pitch="+018.5" yaw="+012.8" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0142">
            <time>
            </time>
            <position pitch="+018.5" yaw="+000.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0143">
            <time>
            </time>
            <position pitch="+037.0" yaw="+000.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0144">
            <time>
            </time>
            <position pitch="+037.0" yaw="+014.4" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0145">
            <time>
            </time>
            <position pitch="+037.0" yaw="+028.8" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0146">
            <time>
            </time>
            <position pitch="+037.0" yaw="+043.2" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0147">
            <time>
            </time>
            <position pitch="+037.0" yaw="+057.6" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0148">
            <time>
            </time>
            <position pitch="+037.0" yaw="+072.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0149">
            <time>
            </time>
            <position pitch="+037.0" yaw="+086.4" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0150">
            <time>
            </time>
            <position pitch="+037.0" yaw="+100.8" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0151">
            <time>
            </time>
            <position pitch="+037.0" yaw="+115.2" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0152">
            <time>
            </time>
            <position pitch="+037.0" yaw="+129.6" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0153">
            <time>
            </time>
            <position pitch="+037.0" yaw="+144.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0154">
            <time>
            </time>
            <position pitch="+037.0" yaw="+158.4" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0155">
            <time>
            </time>
            <position pitch="+037.0" yaw="+172.8" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0156">
            <time>
            </time>
            <position pitch="+037.0" yaw="+187.2" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0157">
            <time>
            </time>
            <position pitch="+037.0" yaw="+201.6" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0158">
            <time>
            </time>
            <position pitch="+037.0" yaw="+216.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0159">
            <time>
            </time>
            <position pitch="+037.0" yaw="+230.4" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0160">
            <time>
            </time>
            <position pitch="+037.0" yaw="+244.8" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0161">
            <time>
            </time>
            <position pitch="+037.0" yaw="+259.2" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0162">
            <time>
            </time>
            <position pitch="+037.0" yaw="+273.6" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0163">
            <time>
            </time>
            <position pitch="+037.0" yaw="+288.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0164">
            <time>
            </time>
            <position pitch="+037.0" yaw="+302.4" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0165">
            <time>
            </time>
            <position pitch="+037.0" yaw="+316.8" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0166">
            <time>
            </time>
            <position pitch="+037.0" yaw="+331.3" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0167">
            <time>
            </time>
            <position pitch="+037.0" yaw="+345.7" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0168">
            <time>
            </time>
            <position pitch="+055.5" yaw="+342.1" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0169">
            <time>
            </time>
            <position pitch="+055.5" yaw="+324.1" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0170">
            <time>
            </time>
            <position pitch="+055.5" yaw="+306.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0171">
            <time>
            </time>
            <position pitch="+055.5" yaw="+288.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0172">
            <time>
            </time>
            <position pitch="+055.5" yaw="+270.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0173">
            <time>
            </time>
            <position pitch="+055.5" yaw="+252.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0174">
            <time>
            </time>
            <position pitch="+055.5" yaw="+234.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0175">
            <time>
            </time>
            <position pitch="+055.5" yaw="+216.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0176">
            <time>
            </time>
            <position pitch="+055.5" yaw="+198.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0177">
            <time>
            </time>
            <position pitch="+055.5" yaw="+180.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0178">
            <time>
            </time>
            <position pitch="+055.5" yaw="+162.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0179">
            <time>
            </time>
            <position pitch="+055.5" yaw="+144.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0180">
            <time>
            </time>
            <position pitch="+055.5" yaw="+126.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0181">
            <time>
            </time>
            <position pitch="+055.5" yaw="+108.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0182">
            <time>
            </time>
            <position pitch="+055.5" yaw="+090.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0183">
            <time>
            </time>
            <position pitch="+055.5" yaw="+072.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0184">
            <time>
            </time>
            <position pitch="+055.5" yaw="+054.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0185">
            <time>
            </time>
            <position pitch="+055.5" yaw="+036.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0186">
            <time>
            </time>
            <position pitch="+055.5" yaw="+018.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0187">
            <time>
            </time>
            <position pitch="+055.5" yaw="+000.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0188">
            <time>
            </time>
            <position pitch="+074.0" yaw="+000.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0189">
            <time>
            </time>
            <position pitch="+074.0" yaw="+030.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0190">
            <time>
            </time>
            <position pitch="+074.0" yaw="+060.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0191">
            <time>
            </time>
            <position pitch="+074.0" yaw="+089.9" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0192">
            <time>
            </time>
            <position pitch="+074.0" yaw="+120.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0193">
            <time>
            </time>
            <position pitch="+074.0" yaw="+150.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0194">
            <time>
            </time>
            <position pitch="+074.0" yaw="+180.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0195">
            <time>
            </time>
            <position pitch="+074.0" yaw="+210.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0196">
            <time>
            </time>
            <position pitch="+074.0" yaw="+240.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0197">
            <time>
            </time>
            <position pitch="+074.0" yaw="+270.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0198">
            <time>
            </time>
            <position pitch="+074.0" yaw="+300.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0199">
            <time>
            </time>
            <position pitch="+074.0" yaw="+330.0" roll="+090.0"/>
        </pict>
        <pict bracket="001" id="0200">
            <time>
            </time>
            <position pitch="+090.0" yaw="+330.0" roll="+090.0"/>
        </pict>
    </shoot>
</papywizard>
by mediavets » Mon Feb 10, 2014 5:41 pm
shayke wrote:Hi con,
Shay
If you have shot a regular grid/matrix pof image s- same no. of images in each row - then you can experiment with Papywizard XML data files, created using Papywizard in simulation mode with no robotic pano head:
http://www.papywizard.org/
Download the latest development version.
