Creating equirectangular (circular) image with 2 fisheye images
freefaller
by freefaller » Mon May 20, 2013 2:25 pm
I'm trying to build virtual tour images with just 2 fisheye images. I use a special fisheye lens that is 185 degree field of view. I typically use iPIX software. When I try to build the image I end up with a panorama and just the 2 fisheye images stacked. What am I doing wrong?
con
by con » Mon May 20, 2013 2:52 pm
freefaller wrote:What am I doing wrong?
with a 5 degree overlap <3% overlap when 25% is whats recommended. Try using 4 photos and another 2 for the top and the bottom and see how much easier life can be:):)
by klausesser » Mon May 20, 2013 3:46 pm
freefaller wrote:I use a special fisheye lens that is 185 degree field of view.
This typically means the diagonal fov. That´s not enough for only two shots.
HansKeesom
by HansKeesom » Mon May 20, 2013 3:53 pm
freefaller wrote:I'm trying to build virtual tour images with just 2 fisheye images. I use a special fisheye lens that is 185 degree field of view. I typically use iPIX software. When I try to build the image I end up with a panorama and just the 2 fisheye images stacked. What am I doing wrong?
Not to be impolite or a smarta** but I think what you do wrong is trying to minimilise the number of photos you need to take. Your aim should be achieving the best result even if it takes a few more photos then just two.
Regards, Hans Keesom
by klausesser » Mon May 20, 2013 4:00 pm
Could you please explain that in detail: "i end up with a panorama and 2 fe images stacked"? Please post a screenshot here.
Which camera and lens do you use? Which head? You really use iPix for that??
