Reducing angle for projection type=Planar possible?
pstein
by pstein » Sat Mar 09, 2013 9:26 am
Is it possible to reduce to angel for projection type=planar by lets say 30%
Currently the projection result is by far too extreme.
I am searching for a way to "soften" the projection angle somehow but keep "Planar" as projection type.
Peter
by mediavets » Sat Mar 09, 2013 9:57 am
pstein wrote:Is it possible to reduce to angel for projection type=planar by lets say 30%
Peter
See:
http://www.autopano.net/wiki-en/action/view/Understanding_Projecting_Modes
http://www.cambridgeincolour.com/tutorials/image-projections.htm
DrSlony
by DrSlony » Sat Mar 09, 2013 10:01 am
Crop = reduce angle
by klausesser » Sat Mar 09, 2013 12:04 pm
DrSlony wrote:Crop = reduce angle
. . . and lose information. I guess he wants to reduce the FOV without losing information.
Let´s say you have an angle of 120°. That´s very distorted in planar projection.
So the goal is to reduce the 120°-distortions while NOT losing parts of the image-content by cropping.
But nevertheless it would be helpful to hear what he wants to achieve . . . :cool:
pstein
by pstein » Sat Mar 09, 2013 12:46 pm
klausesser wrote:But nevertheless it would be helpful to hear what he wants to achieve . . . :cool:
Ok. Here is an example:
At first see the result when rendering with Autopano an "Planar" projection:
Very much black space outside the actual photos
On the opposite see second result created with
MS Image Composite Editor Tool v1.4.4 and "Planar Motion 2" projection mode: Much less black areas.
Moreover Autopanos areas in the corners are very fuzzy/blurry while the one of MSICE are compareable sharp.
How can I achieve a stitch as in MS ICE with Autopano?
Peter
by mediavets » Sat Mar 09, 2013 1:40 pm
Rectilinear (aka planar) prjection is not suitable for a panorama with such a large HFOV.
Did you try playing with the Pannini projection?
by klausesser » Sat Mar 09, 2013 1:51 pm
Peter
Hi Peter!
1) two images are ways too few.
2) shooting spherical (which means to move around one point when shooting) and using planar-projection then means to extremely
blow up the outer regions.
For this reason you need to render it smaller - this way you scale down the center instead of scaling up thje outer regions.
3) Your MS ICE example shows fisheye-distortions. Is that what you want?
Andrew pointed out a very good knowledge base you definitely should read!
