Long flat panorama
pimpoum
Long flat panorama
by pimpoum » Thu Dec 13, 2012 10:50 am
Hi all,
I want to create a panorama a large painting on a very long wall (around 10 metres)...
Is it possible with autopano?
How should I proceed?
The problem is that I cannot take all the pictures from one single position. I'll have to move my tripod along the painting...won't I?
any advice is welcome....
by gkaefer » Thu Dec 13, 2012 11:16 am
http://www.autopano.net/wiki-en/action/view/Reproducing_a_painting_or_artwork
but I've no idea/practise which is better: moving the tripod to take all images from exact 90" angle or to keep camera in one single point and take the images like a outdoor landscape pano...
by Destiny » Thu Dec 13, 2012 11:32 am
Hi..
My suggestion would be to use a wheel dolly system which attach to your tripod legs and then buy some 50mm plastic conduit and make up a track... You then put markers using a marker pen on the track marked off after testing the most appropriate distance of movement from left to right.. You need to make sure your camera is perfectly level. My D800 has a levelling system built in so I am assuming other cameras have the same.. The process works really well and it relativity cheap to setup.. You can also buy heavier gear with rubber or metal track and a heavier dolly system.. But not worth buying if its just a one of project.. There is a mob in India that sell all the hardware, so if you are interested in this option I will dig out the links to their web site..
a a gruntpuddock
by a a gruntpuddock » Thu Dec 13, 2012 1:00 pm
Autopano Giga (not Pro) is designed to handle the situation where the camera changes position.
