Help with Mis-aligned stitching
netline
by netline » Wed Aug 15, 2012 12:49 pm
Good Day All,
I am using a DIY Panohead which is stable and nodle point is acheived, but I keep on having these annoying misalignements everywhere even though I clean up the control points.
Please give me some advice on how to upload images here, so i may post some examples.
Canon 60D, Sigma 10-20mm Lens, Nodal Ninja
by gkaefer » Wed Aug 15, 2012 2:19 pm
dont use the quick posting on bottom...
on bottom right of the most recent posting you can add a posting here than you can select hwo many images you wanna add:
http://www.kolor.com/forum/p65839-2010-07-03-10-10-37#p65839
a a gruntpuddock
by a a gruntpuddock » Wed Aug 15, 2012 2:29 pm
I usually put them on Photobucket then paste the 'share' code into here.
netline
by netline » Wed Aug 15, 2012 3:27 pm
Ok that was easy enough, here are the images
by klausesser » Wed Aug 15, 2012 3:53 pm
netline wrote:Ok that was easy enough, here are the images
Hi!
Clearly the NPP is not matching.
Please tell us some more specific about your setup.
netline
by netline » Wed Aug 15, 2012 3:57 pm
I use a Canon 500D with a 17 - 55mm Original Canon Lens. I have a DIY Tripod Head which i have put into the photo below. The Camera is not properly positioned in this photo
by mediavets » Wed Aug 15, 2012 4:07 pm
netline wrote:I use a Canon 500D with a 17 - 55mm Original Canon Lens. I have a DIY Tripod Head which i have put into the photo below. The Camera is not properly positioned in this photo
At what focal length are you setting your zoom lens?
What shooting pattern are you using?
Looking at the photo of your DIY pano head I can't see how you could ever set the camera/lens at the NPP - for multi-row pano shooting - because the yaw and pitch axes of rotation cannot be aligned.
netline
by netline » Wed Aug 15, 2012 4:12 pm
I shoot totally zoomed out if that answers your question.
And in terms of Pattern I am not sure what you would call it but I generally only do 3 Levels of shots starting with top then go anti clockwise, switch to the middle carry on going anti clockwise and again for the bottom.
Is there a better pattern to use?
by gkaefer » Wed Aug 15, 2012 5:01 pm
independant of used camera, lens and head the NPP can be evaluated for your setup for each focal length with the socalled "grid" method.
you only need some sort of grid (I just use one of these: http://www.ikea.com/at/de/catalog/products/10177606/?query=101.776.06 )
there are several grid-instructions on the web, the first one I found now:
http://rosaurophotography.com/html/technical7.html
(inclusive the original "grid" manual I found months ago for me... http://www.outline.be/quicktime/tuto/ )
netline
by netline » Wed Aug 15, 2012 5:13 pm
Thank you I am going to test this and get back to you
Christian Stüben
Likes: 3 posts
Liked in: 9 posts
by Christian Stüben » Thu Aug 16, 2012 6:42 am
Hmmm, maybe i am wrong, but with your pano head the nodal point can not be adjusted correctly. The angle point (oops, right word?) of the upper bar is not positioned exactly over the horizontal pivot point / axis.
greetings from germany
Chris
